I've had the TomTom One V2 GB since Christmas and love it, great piece of kit that is so easy to use.
I've just started a new job and have been given a TomTom One XL GB, my question is are the SD cards loaded with the same infomation/spec/maps and is it as simple as swopping the cards over to keep all my POI's/speed camera alerts/voices ETC or would I be missing out on something new with the XL SD card?
I know the XL comes pre loaded with speed cameras but at first glance the speed camera POI's I downloaded from pocketgpsworld are much better (the Xl seems to only have gatso's)
