New Alpine amp and 8"JL aUDIO SUB
| | Post Reply |
| | #1 |
danny-p
Guest | New Alpine amp and 8"JL aUDIO SUB Advertisement Want to Advertise?
Hi All, I've just travelled the other side of the country to get an 8" JL Audio sub and Alpine Amp installed into my car... The reason is i have an Audi Quattro which i didn't want to hack to bits so i was having someone install it for me hiding the amp behind the rear speaker cover etc and keeping the new sub enclosed in the hidden side compartment in the boot leaving 100% boot space. The system has worked fine for 3 days then all of a sudden no bass??? I found the fuse in the back of the amp blown and replaced the 30amp fuse and the system sounds a bit distorted.... At first i thought that the distortion noise was only because of the car having half its interior stripped out to mount the amp but it remained once the interior was re-clipped back into place. After several other interior parts removed i gained access to the JL-8W0-4 Sub/box and removed the box. With box removed i tried it again and distortion was just as bad so i removed the sub from its housing and this smell hit me..(it was like a chemical burning smell as if a motor has burnt out)... the sub seems fine visually but could what ever caused the fuse to blow of damaged the sub?? That smell surely can't be normal....the noise is almost like the speaker has a tear in it but it hasn't. Thanks for reading this and look forward to your replies Danny-p |
| Quote |
| | #2 |
| Prominent Member |
It's possible the voice coil in the sub has burned out.This could be the cause of your reported symptoms. Have you also checked for stray wires touching each other either at the amp end or the sub connector end ? Can you connect another speaker on to the end of the amped signal to establish if the amp is ok ? |
| Quote |
| | #3 |
danny-p
Guest |
Hi, I will try connecting another speaker to it tomorrow as for the wiring connector block i found the "remote on" lead had dislodged itself from the Audi loom which i'm presuming had blown the v-coil as you suggested. I'm hoping that the Amp is ok Thanks again Danny |
| Quote |
| | #4 | |
| Prominent Member | Quote:
| Quote |
| | #5 |
danny-p
Guest |
I dont have any other speakers to test the amp with....Would it be out of the question to take thw amp down to halfords and ask them to connect it to a speaker and try it....All i'm worried about is that the amp blows one of their speakers Stuck Thanks Danny-p |
| Quote |
| | #6 |
| Prominent Member |
You could try however i suspect the answer will be they are not permitted to do that. Do you have an old hi-fi speaker or even somthing off an old mini system to try the amp with ? Since it appears to be the speaker which is damaged are you able to get it tested under warranty ?
| Quote |
| | #7 | |
danny-p
Guest | Quote:
Rang around various I.C.E installers via the yellow pages and all said same as you regarding the voice coil. But they also said that although JL Audio are awesome speakers for the money because the bose stereo is only 2-Ohms imp (runs @ 1.5) and the JL-8W0-4 sub is 4-Ohms then the distortion from the higher impedance sub with single voice coil only has caused the speaker to fail blowing the 30Amp fuse. He recommended using the JL 8w3v2-d4 which is a duel 4-Ohm sub which this guy said could wire up to produce a lower impedance? Searching the net i found this jl sub.... ** . Click to enlarge Brand: JL Audio Model: JL-8W3V2D2 Availability: Not Available Online List Price: £149.99 Our Price: £134.99 To Order Call *********** click here to add to system list be the first to review this product Nominal Diameter: 8 inches (200 mm) Continuous Power Handling: 125 Watts Voice Coil: 1.43" diameter, 4-layer, Kapton former Configuration: Dual 2 ohm Xmax (one-way, linear): 0.38" (9.5 mm) Sealed Enclosure Range: 0.30-0.50 cu.ft. (8.5-14.0 liters) Ported Enclosure Range: 0.60-0.90 cu.ft. (17.0-25.5 liters) VRC™ Technology: YES Elevated Frame Technology: No Since their introduction in 1998, JL Audio W3 subwoofers have earned a reputation for outstanding performance and reliability. The introduction of this next generation, the W3v2 models, signals the arrival of some significant upgrades to these already impressive drivers: In addition to JL Audio’s patented VRC™ technology, the 10W3v2 and 12W3v2 also incorporate our patented Elevated Frame cooling technology for enhanced thermal dissipation and 20% more power handling than the original 10W3 and 12W3. Cosmetic upgrades include a new powder-coated silver frame finish, a new dished cone/dust-cap design and a rubber mounting flange gasket that accepts grille mesh inserts directly (these grille inserts are sold separately). The W3v2 subwoofer drivers deliver exceptional tonal balance and impressive output in compact enclosures and are ideal for moderate to high power applications. ** Would this sub be better to fit using the same amp and as its 2-Ohms (same as bose) therefore minimising v-coil distortion? Thanks in advance Danny-p | |
| Quote |
| | #8 |
| Prominent Member |
First things first, you've lost me a little. What does Bose have to do with the problem ? My understanding is the factory fit sounds may have been Bose however the part of the equation is purely the Alpine amp driving the JL sub. Is this correct.If so the amp should be fine driving a 4ohm load (though i assume the fitter has configured the two channel amp to run in bridged mode to now drive a 2 ohm load ?).I'd be inclined to take this up with JL as a potential warranty issue.
| Quote |
| | #9 | |
danny-p
Guest | Quote:
The JL sub i have/had was 75watts with single v-coil and i was recommended a 125watt JL with stronger dual voice coil. What do you reckon bearing in mind the enclosure is pretty small (24"x11"approx) to fit in the compaertment so maybe the small enclosure had some affect on the cause of the coil blowing? Cheers Danny | |
| Quote |
| | #10 |
| Prominent Member |
I am not an expert in subwoofers however my understanding of dual voice coil setups is to allow a greater degree of flexibility when used in multiple sub setups and or to achieve low impedance loads when paired with a suitible amp. In your situation my gut feeling is the speaker was substandard for some reason. I would be inclined to stick to another single coil setup as i don't feel that in your case a dvc sub will be of benefit ie your amp is being presented with a suitible load when fitted 'normaly', hope that makes sense.Did the original dealer recommend the setup you are using, and if so can you go back for help in resolving this issue ? Perhaps somone with experience of installing these could offer specific advice.I seem to recall somone posting that they had many years experience carrying out installations. |
| Quote |
| | #11 | |
danny-p
Guest | Quote:
The install was carried out some 300 miles away by someone i'd contacted from another forum....His reaction is "wierd" "thats strange that is" "i can't understand how thats happened" and so on so i'm not getting anywhere. From the other forum he's apparently done this bose sub upgrade on several other peoples cars and all seem okay?? Which sounds like i'd been given a dodgy sub in the first place but even more strange is how its ran for 3-4 days perfectly then it blows the Amps 30 amp fuse then once fuse replaced sounded horrible? Parts were sourced via ebay also which makes matters even worse. Yeah if anyone with good experience regarding sub installs could help me out that would be great. Thanks again Danny-p | |
| Quote |
| | #12 |
Zoidy
Guest |
hmmmmmmmmmmm.. put the car infront of me.. or any other good ice installer and they could find the problem.. over the net help is difficult. a distored sound leading to a blown fuse i have seen in the past to be caused by a screw through the speaker wire coming from the amp to the speaker. also not enough power being supplied to the amp. without seeing exactly how the amp and sub have been wire up i cant give an accurate opinion hope this helps :/ if you want to speak to someone in the know ring SQ +( www.sqplus.com ).. experts in the very top end of car audio installs Last edited by Zoidy; 06-03-2004 at 12:35 AM. |
| Quote |
| | #13 | |
danny-p
Guest | Quote:
All the Bose cabin speakers are still perfectly clear after the 30 amper blew in the back of the Amp, so this tells me that the fault is from the amp to the sub. Just the v- coil blew in the sub presumeably blowing the 30 amper. The JL Audio that blew was 4-0hm and only a 75 watt single voice coil and i've ordered the 2-ohm 125 watt with dual coils so instead of wiring the 2 channel amp bridged going into the 75 watt sub i was going to wire it up as 2 channel going in to each v-coil at 150 watts each minimising stress on the coils but giving me the same 300 watts to the speaker. What do you reckon, bearing in mind as sub enclosure space is limited so i'm limited to a pretty small enclosure for this 8" driver within the boots side compartment. Cheers Danny=p | |
| Quote |
| | #14 | |
Connect the coils in series and then connect to the amp. | |
| Quote |
| | #15 | |
danny-p
Guest | Quote:
I still don't see the problem with wiring the system up the " independent " route. From the link it said " Parallel " would half the resistance..." series would double it and " independant " went on about house amps etc? See below:- What is the advantage of dual voice coils? The primary advantage of the dual voice coil speaker is wiring flexibility. A single dual voice coil driver offers the user three hookup choices...parallel, series and independent. In a parallel hook-up the drivers impedance will be half that of each individual coil (a dual 4 ohm speaker would be a 2 ohm speaker in parallel.) A series hook-up results in twice the impedance of each single coil (a dual 4 ohm speaker results in 8 ohms if its coils are wired in series.) Finally, you can wire each voice coil to a separate channel of your amplifier, which can be useful if your amplifier is not mono-bridgeable or if you are bridging a four channel amplifier down to two channels to run your sub. The independent wiring application is the one that brought about the need for dual voice coil speakers in home audio. Unlike most good car amplifiers, home amplifiers and receivers are typically not mono-bridgeable. For this reason, dual voice coil woofers were developed so that a subwoofer or center speaker could be driven from the left and right channels of the average stereo home amp/receiver. Since sub-bass frequencies are hard to localize, the dual voice coil subwoofer allowed sub-bass reinforcement within one cabinet and one speaker. This cabinet could be placed inconspicuously in a corner or along a wall of the listening room, with the obvious benefits being space-efficiency and lower cost than two independent bass cabinets or a larger cabinet with two subs in it. Many popular home subwoofer / satellite speaker systems still use this basic configuration. | |
| Quote |
| | #16 |
| Prominent Member |
Since the link appears invalid now i'll copy from their site (they appear to be contradictory in advice) :- ''What happens when you run different signals into each voice coil of a dual voice coil speaker? Essentially, if there is any difference between the signals driving each coil at any given point in time at a given frequency, the voice coils will either fight each other or help each other, depending on the phase relationship of the two signals at that frequency. This is not the same thing as bridging an amplifier and can create undesirable non-linearities and distortion because different input signals at each voice coil create shifts in the speakers electrical parameters. For this reason, it is advisable to mono-bridge the amplifier whenever possible and connect the voice coils of the dual voice coil speaker together in parallel or series. If a dual voice coil subwoofer must be wired to two independent channels, the inputs to both channels should ideally be the same (summed mono) and every effort should be made to match the gains of both channels as closely as possible''. http://www.jlaudio.com/tutorials/dvc/diffsignals.html |
| Quote |
| | #17 | |
danny-p
Guest | Quote:
I'm confused as what to do now as i've been taking advice from this I.C.E. installer who recommended this 2-Ohm JL Audio sub not the 4-Ohm and now i've drilled and mounted 2 more speaker terminals into the subs enclosure. And wired/re-mounted the amp in the most awkward location in the independent " route way also. All i'm waiting for now is the sub to turn up. So what your saying basically is wiring the sub the independant way will/may put more stress on the v-coils at 150Watts compared to 1x300 watts on the v-coils? Cheers Danny-p | |
| Quote |
| | #18 |
| Prominent Member |
You may find the following (hopfully working links usefull), http://www.rockfordfosgate.com/scrip...cGFnZT0x&p_li= RF also have wiring applications on-line,however for dvc subs they have only diagrams for 2 units and greater. |
| Quote |
| | #19 | |
danny-p
Guest | Quote:
I'm gonna wait til the new sub arrives and see manual that comes with it for final opinion. Cheers Danny | |
| Quote |
| | #20 | |
danny-p
Guest | Quote:
Speaker arrived and also managed to download a PDF file for the Amp and you were right. Both recommend bridging the amp in series to gain a 4-Ohm resistance from my 2-Ohm JL Sub. Cheers Danny-p | |
| Quote |
| | #21 |
| Prominent Member |
Glad to have been of some help.The main thing is your on the way to getting sorted. Was the original sub sold to you as a new unit ?
| Quote |
| | #22 | |
danny-p
Guest | Quote:
I Asked the installer to send me the subs reciept and i would chase it up with JL....He sent me a cheque for the amount of the sub and apologised for the inconvenience which i can't grumble about. Thanks Again. Danny | |
| Quote |
| Post Reply |
E. & O.E.
LinkBack URL
About LinkBacks
