| odd antenna jack - help!
Hi, I'm trying to install a new head unit (Pioneer) into a 2001 Subaru Outback (Australian stock if that makes a difference) , but I'm experiencing some difficulties with the antenna plug.
Frustratingly, I had just spent an hour dismantling the fascia before realising the antenna jack was wrong.
It looks like I need some form of adaptor, but am having trouble identifying and sourcing whichever one would be appropriate.
I assume the new HU is a DIN connector (cylindrical, single pin).
The existing OEM antenna jack is cylindrical, quiet wide (~50% wider than the DIN antenna socket) and with 2 parallel pins
(the HU I removed was a Clarion, if that is relevant).
Many thanks,
Ali
