| Re: Ford KA radio stuck
If you are using the correct tools which probably look like 2 U shape pieces of metal, ensure they have been pushed in all the way into the holes.
You may find the cage is still stopping the unit come out only slightly so try and wiggle it to release any of the pieces of metal from the cage.
You could also try and use a torch to see if theres anything stopping it come out. I've always found you have to be quite forceful but wouldn't advise this, instead maybe take it to a local garage and see if they have any idea.
The ford KA may be completely different to the cars i've seen in the past but I would imagine that is quite unlikely.
