Ford CD 6000 radio fault
Old 14-11-2009, 8:38 PM   #1
2,234, Level: 10
Points: 2,234, Level: 10 Points: 2,234, Level: 10 Points: 2,234, Level: 10
Hello
I wonder if anyone can help with my 2005 Ford CD 6000 radio. The on/off button has stopped working and the radio will only come on intermittently, usually when going over a cattle grid or over a rough unmade road. Any help or advice would be most appreciated.
Will
Old 21-11-2009, 8:09 PM   #2
3,475, Level: 13
Points: 3,475, Level: 13 Points: 3,475, Level: 13 Points: 3,475, Level: 13
Thanks: Gave 5, Got 0
Originally Posted by Will Tweedy View Post
Hello
Will
I'm having intermittent faults with mine too - it has power but mostly sticks in the Phone mute mode.
In your case it sounds like a loose connection at the back.
If you're at all handy, buy a set of four removal keys off eBay for < £10 and get the unit out. Then re-seat all the cables at the back.
I'm debating whether to do that or treat myself to a new unit, probably the Alpine CDE-103BT so I can use my iPod and mobile phone in the car.
My local Ford dealer wanted to take it out and send it off, and charge me regadless of whether it can be fixed!
Old 21-11-2009, 9:37 PM   #3
2,234, Level: 10
Yes I have removed the unit and re-seated the connector block. I still cannot turn it on and off with the button but at present it's on all the time. I think it has to be the on/off button that's faulty.
Will
Old 21-11-2009, 10:38 PM   #4
3,475, Level: 13
Will
Oh, OK.
Unless you can fix it yourself somehow it's probably uneconomic to repair then.
You could get a replacement on eBay - loads there - or treat yourself to a new non-Ford unit .
Old 30-12-2009, 7:05 PM   #5
1,236, Level: 7
Points: 1,236, Level: 7 Points: 1,236, Level: 7 Points: 1,236, Level: 7
Originally Posted by brookie View Post
I've got this problem also, but i cant find any information on what causes it or how to fix it.
Did you find a solution?
Old 30-12-2009, 8:16 PM   #6
3,475, Level: 13
I got a guy at Halfords to take it out an reseat it. It seemed to cure it for a while but is playing up again.
My theory now is that the battery is low - I don't drive the car very much and had to jump start it recently. The radio seems to come on after driving for a while.
Might get a new battery and see if that helps.
Old 04-01-2010, 5:31 PM   #7
2,234, Level: 10
I removed the radio leads then replaced them. The radio is still on all the time so I've just turned the volume down until needed.
I think the main problem is a dry joint within the radio but whilst it still works I'm leaving well alone.
Will
Old 04-01-2010, 6:09 PM   #8
3,475, Level: 13
Follow up: I gave the car a good run over Christmas and the radio is currently working again. So, I think, in my case at least, the problem was due to poor battery voltage.
Old 04-01-2010, 7:53 PM   #9
sbw sbw is offline
2,381, Level: 11
Points: 2,381, Level: 11 Points: 2,381, Level: 11 Points: 2,381, Level: 11
Thanks: Gave 0, Got 4
Im having problems with my 6000cd recently in my CMax switching to phone mode all the time even though I have no hands free kit in the car and as far as I can tell there has never been one (car previously belonged to a relative and he never had one) Its nothing to do with the button on the radio that has a picture of a phone, that just mutes the radio so you can talk. I have bought some keys to remove the radio from ebay and am struggling to get the radio out to have a look behind. Is there a knack to it? My fingers are red raw as I type this. The suggestion of it being due to a low battery is a good one as the car hasnt been far in this bad weather we are having.
Old 04-01-2010, 9:47 PM   #10
3,475, Level: 13
There's definitely a knack - I watched the Halfords guy do it and even though he fits radios every day it took him a few minutes. Have a Google for tips and maybe even a video. Seems you have to get all keys aligned and pull simultaneously.
If you have a battery charger try that route first maybe?
If you end up changing radio don't go the Ford dealer route. For the price they charge to take it out and send it for assessment you could get yourself a nice CD/MP3/iPod enabled unit.
Old 05-01-2010, 12:26 AM   #11
4,536, Level: 15
Points: 4,536, Level: 15 Points: 4,536, Level: 15 Points: 4,536, Level: 15
Thanks: Gave 126, Got 37
Had problems with mine, the cd always used to skip after 20 mins or so, eventualy it wouldn't turn on at all, got one on ebay for about £60.
Old 18-01-2010, 1:57 PM   #12
1,236, Level: 7
Thanks for the follow up - mine is behaving in a very similar way to yours.
I bought the car recently, so it hasn't been used much over the past few months. In the week prior to the radio fault, I hadn't driven it at all.
After a trip down the motorway, 40 miles or so, the radio came on and was fine for a few days. Then, as before, less car usage, and the fault re-occurred.Also, my air-con makes my engine revs drop immediately after starting, and sometimes dims the lights.
More recently there's been a clicking noise inside the cabin when i turn the lights on, or when the wipers go up - I'm not 100% but ive been told it could be a starter solenoid/alternator issue - not necessarily serious - but very much linked to a low voltage battery.
Pretty much everything hints at a low battery. I'll charge it tomorrow or this week and report back.
Thanks again for your feedback.
Powered by
 Latest popular product prices
Sony XS-F1337SE 5 inch 13cm 3-Wa...
1 price
 £28.28 Click to show/hide the offers
1 price
1 price
Excalibur X500.2
1 price
 £39.99 Click to show/hide the offers
Excalibur X500.2
1 price
Excalibur X500.2
1 price
In phase PA1200
1 price
 £149.99 Click to show/hide the offers
In phase PA1200
1 price
 Updated February 12th at 7:30pm. Prices include delivery.
