First sorry for my bad English, second sorry its been mentioned here million times but Im unsure how to make it so I have to ask again...
In my car (ford focus 2007 european model, like this one
http://www.caradvice.com.au/wp-conte...dfocus2007.jpg) I have CD like this one
http://www.img.ba/yajv, rest of the story you know, no aux cable in the glowe box and Ford want 70 euro for the cable...
I Have found how to make a cable and thats probably ok
http://www.img.ba/mt4i,
http://www.img.ba/df52
but I cant pull the CD out, there are no holes like in previous versions of ford 6000 CD player !
On this forum I have find this explanation but Im not sure does it refer to my CD model
"To remove the stereo, pop the silver trim off around it, start at the sides and work around to top and bottom. This will reveal 4 screws holding the radio in. The connection is quadlock and not standard Sony. No direct ipod control is currently available. To remove the glovebox, open the glovebox remove all the screws along the top, then pop open the three cover at the bottom and remove these screws, the door stays in place but slide the whole thing out unplugging the aux in socket as you do this. You could then remove the socket from the glovebox and plug it back in behind and run the lead wherever you want it. "
Is there anyone that can tell me how to pull the my model of CD out so I can plug the connectors ?
Do I have to pull the glowebox outside ? I planned to somehow strech my hand and push the 3.5 connector thru the hole from the back of the glowebox without disassembling of the glowebox, is it possible ?
Thanks guys, sorry for asking same question again...
ps
By watching of the position of the CD holes I figured that probably I should in fact remove whole plastic mask
http://www.img.ba/mdhx around the ventilation knobs and cd ? Do I have to do that ? Any suggestion how to make that without breaking it ? Maybe there is some picture shoing where are the places where is it connected to the car ?
On this picture
http://www.fitaudio.com/storedimages...ocus_07/h3.jpg I can see that there are 2 screws so pulling it toward myself is not possible ?!
