Which sat nav just for UK ?
Old 11-11-2009, 3:50 PM   #1
1,372, Level: 8
Points: 1,372, Level: 8 Points: 1,372, Level: 8 Points: 1,372, Level: 8
Thanks: Gave 1, Got 0
Hi, I'm looking to upgrade my sat nav. I don't need European maps, just UK, and I need the maps to be easily updateable, preferably free. Speed Camera detection and re-routing are preferable as is Blue-tooth.
I'm looking spend approx £150, maybe a bit more. I've heard its possible to get a cheap unit and download maps from other more expensive manufacturers to save a few quid, not sure how practicle or legal this is though.
Thanks in advance.
Steve
Old 12-11-2009, 2:17 AM   #2
Illustrious Member
namuk's Avatar
40,920, Level: 49
Points: 40,920, Level: 49 Points: 40,920, Level: 49 Points: 40,920, Level: 49
Activity: 59.5%
Activity: 59.5% Activity: 59.5% Activity: 59.5%
Thanks: Gave 1,068, Got 2,470
Re: Which sat nav just for UK ?
TomTom go Series would do you, 500 series
Old 12-11-2009, 8:55 AM   #3
1,372, Level: 8
Thanks, I've had a look at this on the Tom Tom website, but it doesn't mention re-routing or being able to download new maps or speed camera detection.
Old 12-11-2009, 3:58 PM   #4
Illustrious Member
namuk's Avatar
40,920, Level: 49
Activity: 59.5%
you Get latest map when you first buy it Via Tomtom home , you cn also buy maps on there too , speed cams you have to subscribe to that ..
re-routeing you Need traffic (Hd) or the TMC device then your tomtom detects Jams and gives you the Option to Re-route .
Old 12-11-2009, 7:22 PM   #5
1,372, Level: 8
That all sounds a bit complicated, are there no alternatives that fulfill my needs without having to pay extra for stuff ? I'd prefer just to pay for something that does what I want it to do instead of then paying extra for subscriptions and the traffic (Hd) or the TMC device, which I don't even know what they are !
Old 12-11-2009, 10:55 PM   #6
15,822, Level: 30
Points: 15,822, Level: 30 Points: 15,822, Level: 30 Points: 15,822, Level: 30
Thanks: Gave 583, Got 289
TomTom, portable GPS car navigation systems Less than a tenner from ebay.
Old 12-11-2009, 11:06 PM   #7
Illustrious Member
namuk's Avatar
40,920, Level: 49
Activity: 59.5%
Tomtom home Is very easy Install Software and plug the TomTom unit into base you get supplied, everything is on screen yes/no ect .. no bill Gates Degrees required , Dead easy ..
Then all you do is get Latest map in Home in tools section (top left) ..
Powered by
 Latest popular product prices
Sony XS-F1337SE 5 inch 13cm 3-Wa...
1 price
 £28.28 Click to show/hide the offers
1 price
1 price
Excalibur X500.2
1 price
 £39.99 Click to show/hide the offers
Excalibur X500.2
1 price
Excalibur X500.2
1 price
In phase PA1200
1 price
 £149.99 Click to show/hide the offers
In phase PA1200
1 price
 Updated February 13th at 1:30am. Prices include delivery.
