Originally Posted by LostIn I own a 2003 Passat with the factory Gamma head unit (no CDP). I'm thinking of adding a CD shuttle, or another option would be the xCarLink MP3 player.
Does anyone have experience with the xcarlink into a VW Gamma, and if so, how does it sound?
I'm also interested to know where in this setup the DAC lives. Is it in the xcarlink, or does the Gamma head unit have a DAC which converts the digital signal from the xcarlink? If this is the case I could easily be swayed to purchase one (even a cheaper one from Hong Kong via eBay).
Many thanks. |
I remember reading somewhere that there is some odd connections to do with the radio and diagnostic connector in most if not all VAG (Volkswagen, Skoda and some others) vehicles that involves power (12v from the battery). Some of the connections are non industry standard, and you WILL blow something. It is only certain to be ok if you use products made by VW group, so find out and be very very careful if you intend using anything made by another manufacturer. Sorry I do not know details, only that you must look into it first.
