BMW z4 iPhone no USB Audio Interface
Old 11-11-2009, 12:23 PM   #1
3,462, Level: 13
Points: 3,462, Level: 13 Points: 3,462, Level: 13 Points: 3,462, Level: 13
I've just bought a 2009 (latest model) Z4 with bluetooth preparation but it hasnt got the USB Audion Interface option. I have ordered the iPhone cradle that provides power and connects the phone to the car aerial. The phone connects to the BMW professional Radio via Bluetooth and I can use it to make calls.
I want to play music from the phone on the radio. I was told by BMW that I would need the USB Audio Interface option to do this (but it will cast £000's to retro fit it to the car).
I am not sure how that would work anyway as the iphone conector is not available to plug into a cable to the USB port when it is in the cradle.
Does anyone know how I can get my radio to play music from my iPhone?
Steve H
Old 13-11-2009, 10:43 AM   #2
1,721, Level: 9
Points: 1,721, Level: 9 Points: 1,721, Level: 9 Points: 1,721, Level: 9
Re: BMW z4 iPhone no USB Audio Interface
[Comment removed by mod] Your Iphone will play through the cars bluetooth, as it is. Look at the instruction books for the Iphone, and the cars "entertainment system", the Buisiness radio.
Old 30-11-2009, 2:00 PM   #3
2,452, Level: 11
Points: 2,452, Level: 11 Points: 2,452, Level: 11 Points: 2,452, Level: 11
Thanks: Gave 17, Got 86
I've got a 09 e90 with bluetooth hands free but not the usb.
Beware of the iPhone cradle. It's a bit of a tight fit on my 3GS and I think it broke the power button on my phone. Replecement phone is an even tighter fit so I haven't used the cradle...
I bought a bluetooth stereo gateway to send an audio signal to my car whilst using the bmw cradle. It works really well! This also means I can keep the phone anywere in the car and have wireless music.
BlackBerry Bluetooth Stereo Gateway: Amazon.co.uk: Electronics & Photo
The only slight problem I've had is due to start up problems with the two bluetooth systems. They can somethimes interfere causing an audio drop out. The cars bluetooth comes on as soon as the radio is turned on, or if left on as soon as you insert the key-fob. The gateway takes power from the power outlet/cigarette lighter which only comes on when the engine is started.
The solution is to turn off the radio before the engine every time you leave the car. When you get in start the engine. Select the music you want to play. Once the gateway appears in place of the volume bar on the iPhone press play and turn on the radio. This is normally about 10-15s after starting the engine. If you get a drop out leave it a bit longer.
This way allows good quality un-interupted music and the telephone system to work perfectly, pauses music to take call. Also, this is really useful if you have tomtom on your iPhone as the directions come over the bluetooth gateway pausing the music.
I hope this helps.
Powered by
 Latest popular product prices
Sony XS-F1337SE 5 inch 13cm 3-Wa...
1 price
 £28.28 Click to show/hide the offers
1 price
1 price
Excalibur X500.2
1 price
 £39.99 Click to show/hide the offers
Excalibur X500.2
1 price
Excalibur X500.2
1 price
In phase PA1200
1 price
 £149.99 Click to show/hide the offers
In phase PA1200
1 price
 Updated February 13th at 12:30pm. Prices include delivery.
