setting speaker volumes
Old 02-11-2009, 8:07 PM   #1
2,212, Level: 10
Points: 2,212, Level: 10 Points: 2,212, Level: 10 Points: 2,212, Level: 10
Thanks: Gave 7, Got 0
I've just replaced the four factory fitted speakers with infinity kappa's all round and added an active sub in the boot.
What I'm trying to find out is if I should let the sub handle all the bass as in literally turn the bass off on the kappa's and let the sub do all the low end work.
Is this the done thing or am i barking up the wrong tree
any advice would be much appreciated
Old 02-11-2009, 8:12 PM   #2
drivinscool's Avatar
7,099, Level: 20
Points: 7,099, Level: 20 Points: 7,099, Level: 20 Points: 7,099, Level: 20
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 157, Got 157
Re: setting speaker volumes
Is your system (main speakers) running with an external amp, or just from the head unit?
Old 02-11-2009, 8:18 PM   #3
2,212, Level: 10
just off the head unit
Old 02-11-2009, 8:26 PM   #4
7,099, Level: 20
Activity: 2.0%
In that case i'd leave the bass at a reasonable level for the main speakers. If you do upgrade later on and amp the speakers buy an amp with a HPF (high pass filter) this will filter some of the low bass away from the infinity's which will allow them to go louder without flapping.
By just turning the bass down within the tone controls of the head unit you'll change the character of the sound and it will become a bit thin, you'll lose all the mid-bass punch.
Experiment with it though and see how much you can turn the bass down to avoid distortion without it sounding naff. It's your car and your ears
clayf1ghter (02-11-2009)
Old 02-11-2009, 8:48 PM   #5
2,212, Level: 10
thats great thanks for the advice I'll have a play tomorrow
Powered by
 Latest popular product prices
Sony XS-F1337SE 5 inch 13cm 3-Wa...
1 price
 £28.28 Click to show/hide the offers
1 price
1 price
Excalibur X500.2
1 price
 £39.99 Click to show/hide the offers
Excalibur X500.2
1 price
Excalibur X500.2
1 price
In phase PA1200
1 price
 £149.99 Click to show/hide the offers
In phase PA1200
1 price
 Updated February 12th at 11:30pm. Prices include delivery.
