| Garmin Nuvi 205 or Tomtom One IQ ?
Hi all and thanks for having a look.
I am in desperate need of a new SatNav. Budget is tight as well.
My brief research has provided me with above mentioned two Units.
Nuvi 205 because I have used it before and its very easy to use + no cost to update the map or the firmware etc.
One IQ because of its features.
What do you recommend ?
The other thing, I am made to believe is Tomtom units require subscriptions to carry out general functions, like notify Speed Cameras, update maps, update firmware. I am very concerned about the after purchase subscriptions. I would not like to get in situation where I have to make payments to be able to use unit when I have paid to do certain function.
Can you pls help me.
Many thanks in advance.
sh3hryar
