Well, I've just bought mine and I'm mightily impressed. Also had to call the helpline number to arrange for the Premium TMC to be enabled for free download (0871-2880154). If they need any prompting, just tell them to look on the box of the UK version from Halfords and they'll sort you out.
Weirdly, I wasn't able to select speed camera alerts until after I had paid for and downloaded Freshmaps - presume this was a glitch for me as no-one else seems to have had this problem.
Great routing though - nice looking product and the satellite locking is pretty quick, a matter of seconds normally. Bluetooth works well - decent enough speaker although the mike is apparently quite muffled for the other caller, YMMV depending on where you have the device located - mine is attached to the bottom of a very angular, raked windscreen so quite a long way away from where I sit. Also doesn't help that my engine is quite loud
But couldn't recommend it highly enough - 3 route options all calculated very quickly, relatively easy to use (although I'm a bit of a geek, wife might not find it so easy) and a nice looking toy.
Now how do I get it to play DVDs??
