tom tom one iq ?
Old 06-09-2009, 9:36 AM   #1
gunner84's Avatar
6,849, Level: 19
Points: 6,849, Level: 19 Points: 6,849, Level: 19 Points: 6,849, Level: 19
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 21
tom tom one iq ?
hi
im thinking about upgrading my first edition tom tom to the tom tom one IQ routes edition.
my one is very bulky and does not pick up great reception without using a extra cable i got for it which gives it full reception.
Is the tom tom one IQ good and do the new sat navs get better satelite reception now days compared to the older versions?
thanks
Old 06-09-2009, 10:15 AM   #2
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
Re: tom tom one iq ?
just looked into navigons and the Navigon 4350 im hearing a lot about navigons on here and how they seem to be better than the garmin , tom tom.....
what i want in a sat nav is good reliability and good map routeing , will the Navigon 4350max give me this?
thanks
Old 06-09-2009, 10:53 AM   #3
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
after looking again im finally going for the navigon 3300max from halfords , anyone got this ?
one thing i cant seem to find this one on navigons website ?
Old 06-09-2009, 11:27 AM   #4
5,187, Level: 17
Points: 5,187, Level: 17 Points: 5,187, Level: 17 Points: 5,187, Level: 17
Thanks: Gave 29, Got 5
the tomtom has the best interface IMHO
the tomtom one IQ or tomtom one, has limited non upgradeable on-board memory. if you do go for it, be sure, if you buy the UK version its all you will ever want as whist you can buy Europe maps at a latter date they will no fit on the TT1 uk
Only the TT1 europe has the space for extra maps
Old 06-09-2009, 1:49 PM   #5
4,837, Level: 16
Points: 4,837, Level: 16 Points: 4,837, Level: 16 Points: 4,837, Level: 16
Thanks: Gave 40, Got 61
The 3300max is great, but I swapped mine back for a 4350mac a you get premium tmc and a lot more for the extra £40. The routing is quicker than a tomtom and the myroutes function takes tomtoms iq routing, and improves it.
Old 06-09-2009, 9:45 PM   #6
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
are the tmc and speed camera's a subscription based service on the navigons?
thanks
Old 07-09-2009, 8:50 AM   #7
4,837, Level: 16
No subscription needed, they are free for life.
Also you get 2 years worth of map updates for £17...And they are updating once every 3 months
Old 07-09-2009, 10:01 AM   #8
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
hi guys
i got the 3300max in the end , im a bit stuck on the registration process is asking me for a software version in step 1 , theres a list of about 8 called mobile navigator7 and so on ...
i cant find anywhere what im to select?
please help
thanks
Old 07-09-2009, 10:08 AM   #9
1,640, Level: 9
Points: 1,640, Level: 9 Points: 1,640, Level: 9 Points: 1,640, Level: 9
Thanks: Gave 9, Got 0
Hi what made you swing towards Navigon? I took is looking at tomtom or garmin now considering navigon
Old 07-09-2009, 11:27 AM   #10
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
on here really ,
ive updated the maps but when i go into settings and map display it says europe version q2 2009 ? is this correct , also it keeps turning off everytime i go to the maps.
Old 07-09-2009, 1:07 PM   #11
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
hi
ive got some problems with the 3300max , im not sure if its minor or a fault , it hardly picks up satelites and alsoeverytime i attempt to browse map or it wants to go onto the map screen for navigation it just turns off and restarts ?
anyone
cheers
Old 07-09-2009, 1:16 PM   #12
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
ok guys ive just done a restore and tryed it again and i can now view my maps???
so what did i do wrong last time?
Old 07-09-2009, 1:18 PM   #13
1,640, Level: 9
From the problems you're having you should have not picked Navigon
This swings my view towards tomtom now
Old 07-09-2009, 1:23 PM   #14
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
mate i think it was a minor issue , ive got maps now and it is a very nice interface , i was looking at tom tom as well today in halfords but the navigons looked a lot smarter, im getting satelites now ,so perhaps it was because of being new and had to find a them
Old 07-09-2009, 1:38 PM   #15
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
ive noticed in the settings that im using europe version Q1 2009 and when i clicked latest maps on the navigon software it says british isles Q2 2009 ?
not got a clue what im doing with the updating process?
Old 07-09-2009, 1:38 PM   #16
1,640, Level: 9
I don't like the navigon interface, or the look of the system. I am still unsure as well whether to buy tomtom, garmin and navigon.
Does naigon have free traffic updates?
Old 07-09-2009, 1:57 PM   #17
4,837, Level: 16
Yes, the navigon gets free traffic updates.
Old 07-09-2009, 2:02 PM   #18
4,837, Level: 16
The 3300 max is UK only, so maybe you got the wrong maps. The 3300 doesnt have free traffic updates, its the 4350, just to amend my previous post. I never had any issues in updating or getting satelites. Here is a tip though, do not power down the unit totally when you arent using it, put it in standby. That way when you next power on, satellites will be picked up in seconds, not minutes. There are lots of other little features that i like and keep stumbling across. Maybe i should read the manual to find them all!
gunner84 (07-09-2009)
Old 07-09-2009, 2:14 PM   #19
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
everything seems ok now , ive even updated the maps , i like how it narrows down your search when you type a address
Old 07-09-2009, 3:36 PM   #20
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
i think my topic title should be changed to navigon 3300max , anyway could someone help me with the best place to get cases for the navigon's?
thankyou
edit* also does anyone have the text to speech addon , im thinking of getting it eventually but is it worth it?
Old 07-09-2009, 6:22 PM   #21
4,837, Level: 16
I have the text to speech on the 4350, its good. I dont know how much it is to buy though.
Old 11-09-2009, 2:40 PM   #22
gunner84's Avatar
6,849, Level: 19
Activity: 2.7%
hi
ive found a minor voice error on my navigon 3300 ,at a turning it says bear right but it should say turn right .
can i change this myself or is there a place to report map errors?
thanks
Powered by
 Latest popular product prices
Sony XS-F1337SE 5 inch 13cm 3-Wa...
1 price
 £28.28 Click to show/hide the offers
1 price
1 price
Excalibur X500.2
1 price
 £39.99 Click to show/hide the offers
Excalibur X500.2
1 price
Excalibur X500.2
1 price
In phase PA1200
1 price
 £149.99 Click to show/hide the offers
In phase PA1200
1 price
 Updated February 13th at 4:30am. Prices include delivery.
