Anyone bought a non-OEM BP-819 equivalent battery (or the smaller) and recommend a supplier?
See the larger ones go for around £24.99 with charger but have to watch since some are around 1400mAh whereas others are around 1780mAh, i.e. will last longer.
Anyone tried these out
Buy CANON BP-819 Battery + Charger Combo : DC-battery : United Kingdom - are they a UK company? You can also buy the battery on its own from them which is good is you want to get a couple (i.e. don't need more than one charger).
