| Re: Problems Uploading Handycam Video To Photobucket
You could play the footage to a settop DVD recorder , the resulting disc would be continuous
Otherwise its just do it on the PC in software nles there is some clever in-camera method
This "problem" also occurs in HDD and flash memory based camcorders . In deed wih tape capture , unless you specify capture without scene change detection, footage also gets captured as clips
This traditinally makes editing easier but a liitle annoying where editing is not desired
For uploading to a web site, I suspect there is no getting past doing it on the PC as one single file. This is relatively simple in most software though
