Originally Posted by Ysatis Thanks senu for your reply.
I'm afraid to say, most of it means nothing to me....I'm a bit green to all of this.
I've used the term data to mean my recorded images from the camcorder, I hope this term is correct and hasn't confused you, but it was the term used when I tried to add more. |
It was confusing and sounded like you meant you have a DVD camcorder
Video is data so that bit I understand
Pls Ignore that post as it refers to a DVD camcorder used to " fill up" a disc periodocally
Filling the disc at once is what I ended up doing as I still have my 'movies' on my pc, but I worry that they may get lost or deleted before I get chance to burn them. I don't really want loads of bitty dvd's. There are times when I might want to burn only 15mins. It would be quite a waste not being able to use the rest of the time on the dvd
In truth you are better off using cheap once use DVD discs rather than rewritable ( which is what you seem to be doing now).Optical media is not as " fuss free" as magnetic or flash media when you need adding with data periodically.
The concept as using a DVD media as one you can fill from time to time is fraught with the risk of losing everything. It might then be that you are playing safe rather than " wasting discs"
It still boils down to the idea of " packet writing, UDF formatting and In some cases multi session .. terms you may not be keen to learn..
( yet)
If you are worried you will lose your data, I suggest you simple make 1 or 2 back ups
For playing the video, you could get a HDD based media player, which you can play off any display. To share just make a single use DVD video
Use te VR mode ( selectable from the camcorder menu)
or
Use HDD/SD card or tape camcorder, You can write to them as you wish
Could you elaborate this for me as my camera is HDD.
Doesnt apply you do have a HDD camcorder anyway
What burning application do you use?
