Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 24th at 2:30am and include delivery.
Cancel Sky HD and Sign Up Again pony1982 Sky HD 38 05-05-2009 3:16 PM
Tonight my HD viewing is... Pecker Blu-ray Movies and TV Programmes 1429 29-04-2009 1:09 PM
Hd "Ready" or "Full" - Specifically..... House Plasma Televisions 9 07-04-2009 10:32 AM
How best to record/archive from SKY+ HD box calamityjane Sky HD 30 03-04-2009 10:11 PM
Old 29-03-2009, 10:54 PM   #1 (permalink)
Thanks: Gave 7, Got 0
MiniDV HD to BD? Easiest way?
I've quite a few HD MiniDV tapes (from a HV20) that I'd like to transfer directly to Blu Ray - is it possible to buy a burner which will transfer the files 'on the fly'? I don't really have the time to start editing/authoring as the tapes are starting to build up
ie Can I connect the HV20 directly to the BD burner and hit record? Would the quality suffer? Could do with a painless lossless conversion!
Any ideas? I haven't got any BD gear yet.
Jamesemt is offline   Reply With Quote
Old 30-03-2009, 9:28 AM   #2 (permalink)
Thanks: Gave 425, Got 2,079
Re: MiniDV HD to BD? Easiest way?
There are some " dedicated burners" which Panasonic and Sony make which can create AVCHD discs . These are DVD discs which have a BD structure, which hold up to 20 min of Hi def material.
These disc are playable on the PS3, and many ( not all) BD players.
I dont believe any actually burn to BD burners
You can of couse also create these on the PC with a normal DVD burner and the appopriate software.. You dont need to edit, but you wil be arthoring . Even the full version of Nero will suffice
It wont be " on the fly" but you need not sit and wait ..
See the above: what you need is a Setop BD burner such as you have DVD recorders now. I havent seen any yet. There may well be prtotypes but they are not mainstream yet and would probably cost too much
A few
Use the PC, in addition to the sugggestion to use a DVD burer ad software to make AVCHD discs,
You can buy a BD burner but it creating the BD ROMs wont be "on the fly " and the cost of BD Media may make you pause and take a step back
Also A decent Quac core or i7 system with 3-4Gb RAM will be handy though not esesntial
Hold on to your tapes
or
Wait till Settop BD burners become mainstream
Whatever you do, you will need a bit of time...
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 30-03-2009, 9:58 AM   #3 (permalink)
Thanks for that - I guess the best option at the moment is to wait...
Old 30-03-2009, 10:04 AM   #4 (permalink)
Well you could make an AVCHD disc as an experiment but if you dont have a PS3, BD player or Software PC BD playback software , It may be one for later
I have an LG BD ROM reader/ DVD writer drive ( £70) and can Use it to play BD discs, create and view AVCHD discs from HDV camcorders ( not unlike the HV20)
My BD players can also play these discs ( Sony 350 and Panasonic BD 35)
It cost less than half the cost of a BD writer and given the cost of BD media, I also decided a PC based BD writer would be for later
S3Stuff
easiest, minidv
[IMG] code is Off
