Originally Posted by coatesy Hi everyone
I'm thinking of buying a Sony TG3 Camcorder and need some advice.
At the moment all I have is a cheap Panasonic Tape Camcorder. To record onto a DVD I just plug the cable from the Camcorder into my DVD Recorder(Not Blu Ray) and just record.
Is there an easy way to just copy the recording to my PC
then burn to a DVD to play on any DVD player.
Is there any special software I need or does that come with the Camcorder.
Does a cable come with the Camcorder or do I have to buy it separately.
Thanks for any advice
Graham |
There is a long TG3 thread ( or 2)
Have a read
With the TG3 transfer of material to PC is by USB. Easy either from the camcorder or stand alone Memory card reader
Software does come with the camcorder but most folk soon go out and get something better
It comes with a USB cable
It also comes with an AV cable with which you can record to standard DVD via a settop recorder albeit in Standard Def , as you wouold with youe Panasonic tape model
Which is this " cheap panasonic model, then?
