Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 3:30pm and include delivery.
Tonight my HD viewing is... Pecker Blu-ray Movies and TV Programmes 1429 29-04-2009 1:09 PM
Panasonic TH42PX80 & Sky HD = lip sync problems JamieBee Plasma Televisions 7 28-03-2009 6:50 PM
Best 26'' hd tv yoyo59 Which LCD TV Should I Buy? 50 28-03-2009 11:54 AM
Just Fitted HD into icybox, how to format it gerbilly Mac Hardware, OS and Software 14 27-03-2009 1:54 PM
Old 26-03-2009, 10:18 PM   #1 (permalink)
sd output to hd tv
can someone shed some light on this justwatched a canon mvx25i sd output onto a high def tv 40 inch and it seemed realy grainy .
not impressed.
then watched output to a normal tv and it seemed better .
why is this .
i swear my old high 8 cam would b
e just about as good
tia
phill
philb is offline   Reply With Quote
Old 26-03-2009, 10:22 PM   #2 (permalink)
Thanks: Gave 5, Got 113
Re: sd output to hd tv
Some Sd broadcasts can be pretty poor on Hd sets more so on fully hd as opposed to hd ready .How did you input the footage
jaymac is offline   Reply With Quote
Old 26-03-2009, 10:28 PM   #3 (permalink)
3 leads coming out from camcorder well one lead at cam end and 3 at tv end
phill
Old 26-03-2009, 10:34 PM   #4 (permalink)
If the leads are all Phono and one is yellow then its composite video then which is the lowest quality.As said you will get away with it on a standard TV
Old 26-03-2009, 11:15 PM   #5 (permalink)
Thanks: Gave 425, Got 2,078
True
Although HD TVs show HD in thier " glory" some are less kind to SD sources
Be that as it may , by using the " yellow phono cable " composite video: you are outputting the least quality from the camcorder
If it has S-video that will be better
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 26-03-2009, 11:36 PM   #6 (permalink)
Conspicuous Member
Thanks: Gave 4, Got 1,199
The best quality you can get is to connect the Camcorder to a PC with Firewire (IEE1394) and create a DVD. That is the best quality you will get out of the Camcorder.
Composite = VERY POOR (Bottom of the rung)
S-Video = Not a hell of a lot better
Etc
Etc
HDMI = Very good quality.
Andy98765 is offline   Reply With Quote
Old 27-03-2009, 9:46 AM   #7 (permalink)
Helpful but I think some explanation is called for
In practical terms , Yes
However, if you want to play from the camcorder directly, that isnt an option
Also the " raw" footage from the camcorder " DV AVI " is the best quality but it isn't practical to use it for playback unless you have unlimited space and use a HDD based media player. to the TV
In creating DVD the DV AVI from the camcorder has to be encoded to mpeg2 .
This involves compressing it considerably which results in far smaller size, compatibility with DVD but quality is generally well preserved if well done
As such Mpeg2 ( on a DVD video) is very good but this depends on the encoder used and the bitrate employed to encode.
Encoders are not equal and some DVD transfers are poor
I agree with that
Not so, Actually s-video is quite a lot better if well implememnted
Usually but there are also cheap HDMI chipsets which are no better than Scart , hence the poor showing of some " HDMI" upscaling DVD players
Component video is good but SD camcorder dont have it . They also do not have HDMI
The OPs camcorder is MiniDV tape model and will most likely only have composit and S-video for playback to TV from camcorder anyway
S3Stuff
output
[IMG] code is Off
