| Question about showing footage in 'fast motion'
Ok, I think I understand the principle of slow motion from a film perspective. Let's say I was working in the 24fps format, and I wanted some of the footage to appear as if it was going in slow motion at half the speed of normal motion, but with the same 'fluidity' of motion. In this case, I would simply shoot the footage at 48fps, and then slow it down to 24fps in post production.
But what if I wanted to do the opposite? If I wanted a piece of footage to go at double the speed of normal motion, but with the same fluidity of motion, how exactly would I need to shoot the footage? Obviously, the final footage would still only be kicking out 24fps, as you can't have multiple frame rates within a finished product!
My first thought was that you simply shoot at normal frame rate (24), and then simply remove every other frame so that 48 frames (2 seconds of time) would be compressed into 24 (1 second of time). But when I thought about this, I realised that this would mean the amount of motion between each frame would be a lot greater, since the intermediate frames had been removed. Wouldn't this then mean that the motion itself wouldn't be as fluid as 24fps, and therefore look a bit jerky?
Is there some basic principle I'm missing here?
Any help is much appreciated!
