Sony HDR-HC3E
Old 06-03-2009, 11:04 AM   #1
1,869, Level: 10
Points: 1,869, Level: 10 Points: 1,869, Level: 10 Points: 1,869, Level: 10
Sony HDR-HC3E
Play.com have Sony HDR-HC3E for around £340. Is a worthwhile purchase at that price or is there a better alternative below £450? I'm not too fussed over formats - I'm used to using DVC but it's kind of irrelevent
I'm not a high end user, it's really just for filming the kids - editing in iMovie - just stuff for posterity really.
Any thoughts/opinions gratefully received.
Matt
Old 06-03-2009, 11:17 PM   #2
1,869, Level: 10
Re: Sony HDR-HC3E
Kind of decided against it. I'm weighing up 4 - HMX20, HG10, SD5 & SD9 - any thoughts?
Old 07-03-2009, 7:26 PM   #3
jwramsay's Avatar
7,566, Level: 20
Points: 7,566, Level: 20 Points: 7,566, Level: 20 Points: 7,566, Level: 20
Thanks: Gave 81, Got 61
Re: Sony HDR-HC3E
I have HC-3 paid around 2x that 2 years ago!
Great camcorder, brilliant results. Mini DV great for archiving your stuff too, £1 odds a tape! Reconsider!!
Old 08-03-2009, 8:13 AM   #4
8,266, Level: 21
Points: 8,266, Level: 21 Points: 8,266, Level: 21 Points: 8,266, Level: 21
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 16, Got 189
Re: Sony HDR-HC3E
yes hdv is a lot easier to edit i have both avchd and hdv,my sr 12 avchd cam has a fraction more resolution playing direct to a tv than my hdv cams but after edit its the other way round,probobly my software ,
Old 08-03-2009, 9:15 AM   #5
1,869, Level: 10
Re: Sony HDR-HC3E
Thanks for the replies.
I'm more confused than ever! I was leaning towards the HG10 (at £340) although I've got misgivings about AVCHD - Is editing that bad? I'm on a new Intel Imac w/4gb Ram...
Ideally, I think I'd be happier with HDV but my budget - £450 absolute tops - is pretty restrictive...
My top priorities are image quality and good image stabilisation. Waiting a bit longer in transferring footage for editing isn't necessarily too much of a problem...
Old 08-03-2009, 9:21 AM   #6
8,266, Level: 21
Activity: 22.0%
Re: Sony HDR-HC3E
you wont get an hdv cam in your price range,but you may be luckier than me and not lose pq resolution during pc import with avchd.
Old 08-03-2009, 10:34 AM   #7
1,869, Level: 10
Re: Sony HDR-HC3E
Yeah. I'm still contemplating getting a standard def miniDV cam...
Old 08-03-2009, 11:34 AM   #8
1,894, Level: 10
Points: 1,894, Level: 10 Points: 1,894, Level: 10 Points: 1,894, Level: 10
Activity: 0.2%
Activity: 0.2% Activity: 0.2% Activity: 0.2%
Thanks: Gave 35, Got 3
Re: Sony HDR-HC3E
My advice would be to go Hi-Def.
Late last year I" upgraded" my Sony TRV50 to the new (tiny) TG3 and the difference in PQ is unbelievable.
Youre correct that editing AVCHD requires a hi-spec pc (a Dell costing £600 ish should cover it) but I suppose you could still capture HD but edit in SD for the time being, and then upgrade your PC at a later date. At least your original footage would still be in HD
Jez
Old 08-03-2009, 1:54 PM   #9
1,869, Level: 10
Re: Sony HDR-HC3E
Yes, that's what I figured but the budget is pretty limiting I'm afraid - I've seen the HG10 and Sony SR8 within my budget but they both seem to have problems when used with Macs (rather PCs) and i'm looking for something that's pretty hassle free...
Old 08-03-2009, 4:14 PM   #10
1,869, Level: 10
Re: Sony HDR-HC3E
Just to add - it was lack of Firewire on the SR8 that put me off.
Old 08-03-2009, 4:17 PM   #11
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Re: Sony HDR-HC3E
USB is fine isnt it.?.
Old 08-03-2009, 6:13 PM   #12
8,266, Level: 21
Activity: 22.0%
Re: Sony HDR-HC3E
ulead studio 11 has solved the problem no loss from the files when sr 12 footage is rendered with it it was pinnacle poo
Old 08-03-2009, 7:07 PM   #13
jwramsay's Avatar
7,566, Level: 20
Re: Sony HDR-HC3E
HDV does not mean hard disk!
The Sony HC3 records in HDV rather than the newer AVCHD.
It is 1440x1080i and uses MPEG2 only to compress the signal to fit in the same bandwidth as DV video.
THIS DOES NOT MEAN IT ENCODES THE VIDEO IN MPEG2!!!!
The footage is stored on mini DV tapes, which is find by me, as I have a library of 50 odds sitting in a drawer - brilliant archive mechanism.
The OP has found that play.com are selling this Sony HC3 for £340, which is a TRUE bargain price.
Armed with the Sony Vegas 8.0c and DVD Architect Pro 5, I am producing AVCHD discs that play on my Sony S350 Blu Ray player. These have full AC3 5.1 and 15Mbps AVCHD Video.
This is why I say to the OP, grab that HC3 before they all go!
Old 08-03-2009, 7:46 PM   #14
47,154, Level: 53
Activity: 2.7%
Re: Sony HDR-HC3E
I think Chris Knows that. he has 2 HDV camcorders ( FX7 and HC1) and SR12 which is AVCHD
What does it encode in then?
HDV is mpeg2 1080i.. Sure it has a transport header (m2t) , differernt codec, pixel size and higher bitrate ( fixed at 25mbps than SD mpeg2 but it is mpeg2 .. such as is found in Bluray discs as well as AVC and VC1
I agree with this as I also have 2 HDV camcorders but the real time download and arguably great quality of newer AVCHD camcorders seems to make less of a case for HDV
True
HDV can be converted to AVCHD ( as you can see).. the converse is also true
Chris was reffering to loss of quality when converting
jwramsay (08-03-2009)
Old 08-03-2009, 9:38 PM   #15
jwramsay's Avatar
7,566, Level: 20
Re: Sony HDR-HC3E
This was the comment I was referring to Senu.
OP stated that he found the Sony HC-3 for £340.
OP suggested that his price range was £450.
As £340 < £450, so an HDV cam is in his price range.
That is why I thought that Chris was thinking HDD.
No worries Senu.
Old 08-03-2009, 9:44 PM   #16
47,154, Level: 53
Activity: 2.7%
Re: Sony HDR-HC3E
No worries Senu.
Im chilled.. cold flowing as we "speak"
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
6 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 12th at 12:30pm. Prices include delivery.
[IMG] code is Off
