| Re: Help - Sony hdr-tg3
Hi David,
As muscleflex has said, do everything via the Picture Motion Browser software that came with your TG3.
You have a number of choices within PMB,
1) either get PMB to create an AVCHD Disk on a DVD disk using all the footage on your camcorder (basically a straight dump), which will play through any Blu Ray player (or better still as suggested go buy a PS3). You get about 25 mins of wonderful HD footage and it all plays together seamlessly
2) via PMB dump it onto your Hard Disk so you can choose which clips you want ohn the disk and which you dont, bearing in mind the 25min rule above (i ammume its double if youve a dual-layer DVD writer). Then write it as a AVCHD disk for your blu-ray/PS3
3) Do either 1 or 2 but when you write it, get PMB to do it as a DVD compliant disk, which will play on any DVD player (although in standard definition only)
Jez
