Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 8:30am and include delivery.
For Sale : Dreambox 500C + Eurovox 7000HD+ sholden5 Home Cinema and Hi-Fi Equipment Classified Adverts 20 27-05-2009 4:42 PM
Old 18-02-2009, 12:15 PM   #1 (permalink)
EasyCap advice for burning to disc please
Hi guys,
I have just installed an EasyCap Video adapter thingy, which so far seems brilliant, even a non-techno idiot like me managed it.
The problem I seem to be having is:
When I first started I managed to burn a test dvd (only bout 3mins worth) just to see if it worked. On my sons tv/dvd (cheap digilogic) it worked, although the sound and picture was slow and slurey. But on my bush 2054divix dvd player it brings up a blue screen with audio and video, i press video but it says JPEG file (even though I know it is an mpeg file). Why does it work on my sons dvd (allbeit slow) and not my bush.
I thought I must have done something wrong so tried to burn another copy but
I can get the video from the player to the file, but when I put in a disc to burn it, it keeps saying 'the disc may not have enough space' then when I click ok, it says 'this action may take some time to render' (cool) but then it says 'this disc is not empty or writable'.
It is a memorex CD-R, brand new out of the pack?????
What am I doing wrong?
Please help, I was doing so well upto that point.
cuddlybunny is offline   Reply With Quote
Old 18-02-2009, 2:57 PM   #2 (permalink)
Thanks: Gave 37, Got 124
Re: EasyCap advice for burning to disc please
If your burning a DVD then you'll need a DVD-R not CD-R, you can make a Video CD with CD-R but it's in a different format from DVD.
glesgaguyav is offline   Reply With Quote
Old 18-02-2009, 5:42 PM   #3 (permalink)
Thanks: Gave 4, Got 51
I think the EasyCap Video adapter thingy , is really a Video capture device . Where did you get your DVD test file from ?? .Are you trying to trying to write to disk directly from the EasyCap as in "on the fly " ??.
Your source file is captured by the EasyCap to a file ,avi ,mpeg etc in a video editing package .You can edit this file and save it . You use a encoder program to put this file onto a DVD. I use Sonic DVD It to put any file [, avi, mpeg ,wmv etc ]directly onto a DVD .
What program are you using to capture ? and what's the source ie , VHS ,DVD etc ??
Technomate 1500+- Lenson 1m-Geotrack Positioner-Panasonic Th37 Plasma-Panasonic NV-GS11-Sharp VL-WD450 -C500-PIN570-Nokia770-Nokia 810-Ubiquio401&501-Imate8502-Navigos 4.3v1 & 3.5v2-
rickyt is offline   Reply With Quote
Old 18-02-2009, 6:48 PM   #4 (permalink)
Thanks for reply. Sorry it is a DVD-R.
Any ideas
Old 18-02-2009, 6:52 PM   #5 (permalink)
I will try to put on a dvd encoder as you said. I just followed the instructions from EasyCap and it says I should be able to plug and burn.
The test file is what the easycap downloaded from a vhs video to my pc. I thought the easycap encluded the editing with the package. Am I that dumb to think it is that easy. I dont know, maybe. But the packaging says it is.
Old 19-02-2009, 7:23 PM   #6 (permalink)
I'm sure the EasyCap device came with software .....................mine did ..........Ulead I think . I know it works although I've connected a camera to it ..........I havn't captured anything .
advice, burning, disc, easycap
[IMG] code is Off
