| Re: DCR-HC96e - AV in HELP!!
Thanks for your help Senu & Rogs.
I have been away, so I have not been able to post.
Rogs you are right, it does have passthrough, and this I found in the instructions, but I could not get any picture through the camera. After much messing about, I found a sub-menu - which I can not see listed in the instructions anywhere - giving you the option to switch between Video & Svideo. Once I found this and switched to SVideo I was able to passthrough. The instructions do tell you to switch to A/V in (which is obvious) but not about the format switching.
Many thanks
Philip
