Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 4:30pm and include delivery.
Help choose which size for room - Panasonic Plasma 42PZ80 or 46PZ80 parmsuk Plasma Televisions 17 12-03-2009 10:20 AM
Any Recommendations For Router With Good Range yukichon Networking and NAS 22 05-03-2009 7:12 PM
Panasonic THPZ80 question Perrioli Plasma Televisions 4 17-02-2009 6:27 PM
service menu panasonic TH46pz85 Dynamo750 Plasma Televisions 14 17-02-2009 6:14 PM
Imac painfully slow on the web adampoll Mac Hardware, OS and Software 9 17-02-2009 5:50 PM
Old 17-02-2009, 3:23 PM   #1 (permalink)
Red face Panasonic HS100 not connecting with iMac
I've recently bought the Panasonic HDC-HS100 and have taken alot of footage with it that I need. I used the HD Writer software that came with it with my Dell laptop but the footage would only play 4 frames per second, I presume that was because the laptop is four years old and just not up to standard. Now I'm using an iMac but the software supplied by Panasonic is only for Windows.
I've connected the camera and still images show fine but I can't get the video footage to open. I've got Premiere Pro version 3.1.1, do I need a newer version. I've also got iMovie 6.0.3 and its the same story but I'm pretty sure that version is too old anyway.
Do I need to download a Panasonic driver that will suit Mac?
Any help would be much appreciated!
lelu is offline   Reply With Quote
Old 17-02-2009, 4:44 PM   #2 (permalink)
A n d r e w's Avatar
Thanks: Gave 31, Got 245
Re: Panasonic HS100 not connecting with iMac
You're right in thinking that iMovie HD doesn't support AVCHD camcorders like the HS100, and in fact does not support 1920x1080 video (or rather, it does - unofficially - so long as you don't use any transitions other than cuts).
As for Premiere, I just looked at the support pages (Adobe Premiere Pro CS3), and while HDV and DV are mentioned as supported formats, there's no mention of AVCHD, which leads me to suspect it isn't supported.
You could try VoltaicHD to convert your .mts AVCHD clips to .mov (which is supported according to the PP support pages, though it's only a wrapper and I'm not sure whether it will import absolutely any .mov) but it's not an ideal solution. Otherwise, the only solution would be to update to iMovie '09 or Final Cut Express, or a more recent version of PP which supports AVCHD.
You could alo try posting here, if you haven't already.
Andrew.
These are the sort of windows faces look in at.
A n d r e w is offline   Reply With Quote
Old 17-02-2009, 7:34 PM   #3 (permalink)
Thanks Andrew, much appreciated. I tried to start a thread where you left a link but it won't let me log in, maybe I'll try later!
avchd, connecting, hs100, imac, panasonic, premiere pro
[IMG] code is Off
