Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Samsung SMX-C10
Panasonic HDC-SD200
 More...Prices updated November 25th at 4:30am and include delivery.
Streaming Help! MP4 Files Stutter When Streamed! VisibleGuy PS3 Media & Streaming 24 28-10-2009 5:23 PM
Sony Ericsson Idou - 12MP Touchscreen Smartphone Tejstar Sony Ericsson Mobile Phone Discussions 56 23-06-2009 10:04 PM
what one do i go for? Pioneer BDP-51FD, BDPLX71 or Sony BDP-S550 tariksul Blu-ray Players 11 16-02-2009 10:36 PM
Earphone help? sauluk Headphones and Headphone Amps 7 16-02-2009 10:17 PM
Sony KDL40V4000 WilkyM3 Which LCD TV Should I Buy? 9 15-02-2009 7:08 PM
Old 15-02-2009, 7:27 PM   #1 (permalink)
Thanks: Gave 20, Got 3
Sony TG1 Help
Hi Sorry if this is a dumb question!!
I have a sony TG1 and am trying to get the videos and pictures from the card on to the PC so i can view them and maybe make a disc or two
Problem is that i have loaded the supplied software (although i am running 64bit vista) and nothing is showing as imported, well thats actually incorrect, its imported but when analyisng the videos are all showing as unreadable
Question is...is there a 64bit programme i can get either free or cheap as chips so i can store and view my videos!!?
Or am i doing something wrong? All the videos work when played back on the camcorder so i assume that they are not corrupted in anyway and i am hoping that its just an avchd thing !!
Any help for a complete noobie really appreciated!
Snobdr is offline   Reply With Quote
Old 15-02-2009, 8:52 PM   #2 (permalink)
Thanks: Gave 37, Got 124
Re: Sony TG1 Help
Check your codecs, PMB doesnt like 3rd party codecs like FFDshow, if you have 3rd party video/audio codecs installed you may have to remove them, there are other posts on this forum regarding this
glesgaguyav is offline   Reply With Quote
Old 16-02-2009, 10:38 AM   #3 (permalink)
Re: Sony TG1 Help
I have tversity on the pc would this cause problems? If i delete the codec pack i wont be able to use my ps3 as a media hub and that would make MRs not happy..lol
I dont understand if I am simply trying to get the videos off the memory stick why the progamme wont play them
Also shouldnt my ps3 play the movies direct from the pc using tversity?
Old 16-02-2009, 2:45 PM   #4 (permalink)
Re: Sony TG1 Help
Not sure whether Tversity would interfer with PMB but you don't need PMB to view the files in anycase, there are plenty of HD players viewers out there, just use one of these instead.You could always try unistalling Tversity.
PMB is good for transferring and organising the clips, however once they're transferred over you can open them in any program that can handle AVCHD files.
Tversity should be able to stream the videos to your PC if it and your equipment is up to it, just look for the .MTS files, although I should think they'll only be played as individual clips
sony, tg1
[IMG] code is Off
