Re: Newbie Advice On Flash Camcorder Choice
The MV200 used a single quarter-inch CCD sensor. The SD9 has three CCDs, but they're smaller - 1/6-inch in fact. So expect the SD9 to be noisier in low light than the MV200. On the plus side, it's sharper (producing more lines of video than the MV200) and the Costco price makes it quite the bargain.
The HF100 is better in indoors / low light situations, employing a single medium-sized CMOS sensor, but as you note it's more expensive.
The TG3 is more or less on par with the SD9, perhaps marginally sharper, but a different form factor.
All three will give you excellent results in bright sunlight outdoors.
Just make sure you've got some practical means of editing / playing back HD video recorded in the AVCHD format used by these camcorders.
Andrew.
These are the sort of windows faces look in at.
