Originally Posted by akkers Assuming that I am going to edit in premiere and burn to DVD what settings should I be using to generate the file for editing?
16x9 or 4x3
128-x720 or 1440x1080
Progressive or interlaced |
For DVD (SD) 576 x 720 is the standard otherwise it will still be scaled down to that for PAL mpeg2
However you can retain the 1440x 1080 and edit as HDV , then output to DVD ( which will still result in 576 x720 resolution files)
As adviced keep it interlaced and dont change the aspect ratio from 16:9
