Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 11:30am and include delivery.
SVS SB12+ vs PV1. Dazzor Subwoofers and Tactile Transducers 13 24-09-2009 3:55 PM
PS3 Eye camera £15.(inc VAT + P&P) @Sony style! travid Gaming Bargains and Discount Codes 19 06-03-2009 1:36 PM
The Bluray title you consider the best upgrade over DVD paulst10 Blu-ray Movies and TV Programmes 25 20-01-2009 10:47 PM
Genuine Battery vs Copy ? jeddati Digital Photography General Chat 9 20-01-2009 5:33 PM
Wanted : Bluray Player : Sony BDPS 550 or Panasonic BD 55 cinetudes DVD and Blu-ray Player Classified Adverts 0 19-01-2009 8:48 PM
Old 19-01-2009, 9:13 PM   #1 (permalink)
Sony DCR-HC96E. 16:9 vs 4:3.
I am trying to figure out how to capture the video taken with a Sony DCR-HC96E we have at work. The camera has a widescreen monitor on it. When I playback the video and looking at the monitor on the camera everything looks ok in the 16:9 format.
But when I capture the video to the computer (have tried both USB and Firewire) it seems like I only get 4:3. And this causes persons in the film to be a bit "pushed".
Also, the resolution seams to be very low. I can select much higher then 320*240.
As you noticed I am not an expert at this. So I would really appreciate all tips
Regards
Erik
edroszcz is offline   Reply With Quote
Old 19-01-2009, 9:16 PM   #2 (permalink)
Conspicuous Member
Thanks: Gave 4, Got 1,199
Re: Sony DCR-HC96E. 16:9 vs 4:3.
Well you have forgotten to state WHAT software you are using on your computer?
Most software has to be told to work in 16:9 in the settings. The original Adobe premiere had to set at boot up if I remember and before you download any film from the camera.
Andy98765 is offline   Reply With Quote
Old 19-01-2009, 9:19 PM   #3 (permalink)
Oh, sorry!
I tried Windows Movie Maker when capturing using USB. And I went for WinDV when I tried Firewire. Didn't really find any 16:9 settings :$
Old 19-01-2009, 10:14 PM   #4 (permalink)
Conspicuous Member
It is in Windows Movie Maker "Tools", "Options", "Advanced". In the UK you need PAL not NSTC and either 16:9 or 4:3 your choice.
Old 19-01-2009, 10:16 PM   #5 (permalink)
Conspicuous Member
AND in Windows DVD maker you also have a options setting. Took less 1 minute to find both?
Old 19-01-2009, 10:28 PM   #6 (permalink)
Thanks alot!
You are right, I should have looked further. It's just that I though you made all settings to video quality and aspect ratio in the wizard. There I just couldn't find it
Gonna try this first thing in the morning when I get back to work!
Old 20-01-2009, 8:13 AM   #7 (permalink)
Did change the Video properties in Windows Movie Maker to PAL 16:9. But no mattar what Video Settins I select in the wizard it sets the resolution to 720*576.
Can't I capture video to a 16:9 resolution like one of the following?
852x480
1280x720
1365x768
1600x900
1920x1080
Old 20-01-2009, 8:37 AM   #8 (permalink)
Conspicuous Member
720*576 is the correct setting. The aspect should be correct once viewed on a DVD player.
BUT do check your DVD player is 16:9 as most people still have them set at default which is either 4:3 or 4:3 letterbox.
169, dcrhc96e, sony
[IMG] code is Off
