Originally Posted by gpc Memory - What's the best / cheapest to use.I have found a SanDisk M2 micro ( I have an adaptor for it to plug into) 8gb on Amazon for £20, is this the best way to go or are there other solutions, ive also found a lexar 8gb pro duo for £18 on Amazon..any good? |
I'd go for the 8gb Pro Duo. This way as well you can then dump the entire contents of the card to a DVD+DL for backup purposes.
Originally Posted by gpc Video editing software - At the moment im running vista, but may be moving to a mac. What's the best video editing software. Nothing fancy, just need it to be idiot proof. |
Sony Vegas on Vista I think and you can get a trial if you want. On the Mac just use iMovie which comes with it, works great with my TG3.
Originally Posted by gpc Output - If I record in HD, once edited can I burn the video to a regular DVD? If so, can I burn it in HD format, and / or SD format (my mates don't have HD players yet). |
You can burn to SD format on the DVD and it'll still be better quality than if you filmed in SD originally. If they have a PS3 you can plug your TG3 direct into the PS3 either by memory card on the 60gb models or buy USB with the docking cradle on the other models (I do this) and it'll work great including the full 5.1 sound.
