13-01-2009, 11:19 PM
#1 (permalink)
| | Member
Thanks: Gave 10, Got 15 | Panasonic VW-BN1 disc burner
Anyone know how the VW-BN1 burner works, Im thinking of buying one for my Pany SD9 to make high def DVDs
If I understand things correctly, it burns a high def recording onto normal DVDs.
Or would I need to use a different kind of disc?
Panasonic TH37PX70 Plasma. Samsung LE46M87 LCD , SkyHD, Panasonic SD9 Camcorder, Panasonic TZ7 Compact, PS3, PSP, 2 smelly dogs & 1 x Nagging wife!
14-01-2009, 12:12 AM
#2 (permalink)
| | Senior Member
Thanks: Gave 1, Got 389 | Re: Panasonic VW-BN1 disc burner
It will burn to standard DVD-R, DVD-RW, DVD-R/DL or DVD-RAM discs.
14-01-2009, 7:19 AM
#3 (permalink)
| | Senior Member
Thanks: Gave 31, Got 245 | Re: Panasonic VW-BN1 disc burner
I believe you need to daisychain the VW-BN1 and your camcorder to your TV set for playback.
__________________ These are the sort of windows faces look in at. |
14-01-2009, 7:44 AM
#4 (permalink)
| | Senior Member
You do. Else you can play the discs back directly in a compatible player such as the Panasonic Blu-ray players.
14-01-2009, 8:48 AM
#5 (permalink)
| | Member
Thanks: Gave 10, Got 15 | Re: Panasonic VW-BN1 disc burner
Cheers for the replies, so does it definately record high-def onto normal DVD-R discs, as opposed to SD.
Think I might have to get one and play the discs in my PS3.
14-01-2009, 3:15 PM
#6 (permalink)
| | Member
Thanks: Gave 62, Got 113 | Re: Panasonic VW-BN1 disc burner
I assume you don't have a computer?
If you have a computer AND a PS3 then there is no point getting one of these. Although I guess the "one-touch" burn aspect might be attractive I don't think these burners are worth the money IMHO.
I would put a sig here, but I can't be bothered...
14-01-2009, 3:36 PM
#7 (permalink)
| | Member
Thanks: Gave 64, Got 12 | Re: Panasonic VW-BN1 disc burner
I agree - I have a similar burner for my Canon cam because my computer is crap and I'm frustrated with its limitations. On the Canon, you can't add stuff to a disc once you've burned it because it's automatically finalised and you can't edit the names of the titles. The one advantage it does have over my current computer is that it can burn to dual layer discs.
It is quick and convenient, though.
14-01-2009, 8:13 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 1, Got 389 | Re: Panasonic VW-BN1 disc burner Quote:
Originally Posted by TheBear843 Cheers for the replies, so does it definately record high-def onto normal DVD-R discs, as opposed to SD.
Think I might have to get one and play the discs in my PS3. | Definitely.
14-01-2009, 9:49 PM
#9 (permalink)
| | Member
Thanks: Gave 10, Got 15 | Re: Panasonic VW-BN1 disc burner Quote:
Originally Posted by Mr Lazy I assume you don't have a computer?
If you have a computer AND a PS3 then there is no point getting one of these. Although I guess the "one-touch" burn aspect might be attractive I don't think these burners are worth the money IMHO. | Point taken but Im not sure my computer is up to the task of using the editing software, heres the spec.
Acer Aspire Laptop
Intel Core 2 dual Processer
120GB HDD
DVD Super Multi double layer
2GB DR2
Im currently copying the SD card onto my PS3 and then reusing the SD card again. But im conscious that I might not be able to ever copy it over from my PS3 to a disc if needed later.
With the Panasonic burner I could make back up copies onto DVD as well as storing on my PS3, but need to confirm it will burn in HD.
But if my computer is powerful enough then I might buy some editing software instead. What do you think???
14-01-2009, 9:53 PM
#10 (permalink)
| | Senior Member
Originally Posted by TheBear843 Point taken but Im not sure my computer is up to the task of using the editing software, heres the spec.
Acer Aspire Laptop
120GB HDD
2GB DR2
But if my computer is powerful enough then I might buy some editing software instead. What do you think??? | As answered previously, the VW-BN1 burns to standard DVD's in HD (AVCHD).
15-01-2009, 10:00 AM
#11 (permalink)
| | Member
Thanks: Gave 62, Got 113 | Re: Panasonic VW-BN1 disc burner Quote:
Originally Posted by TheBear843 Im currently copying the SD card onto my PS3 and then reusing the SD card again. But im conscious that I might not be able to ever copy it over from my PS3 to a disc if needed later. | You should be ok ie. transfer back to the laptop. However I've heard some reports that using the Panasonic software you can't write back to the camcorder but this would need to be confirmed by an SD9 owner. Quote: |
| Yes you certainly need to be making at least one copy plus the original and personally I wouldn't trust using only the PS3 plus a DVD as my only copies, but it depends how precious your video is. For achive copies, an external hard drive for the laptop would probably be best, though burning the video files as a data DVD on the laptop would be cheaper. Quote: |
| Difficult to say, and you didn't give the speed of the CPU and the OS, but my AMD 1.8Ghz dual core laptop with 2GB RAM struggles to even play AVCHD never mind edit. However the only real issue should be getting an adequate preview. Rendering might take a while but you'd leave it overnight anyway. I would suggest downloading trial versions of editing software. Reports suggest that Sony Vegas Movie Studio Platinum requires the least amount of CPU grunt (my experience backs this up but then I haven't tried all the different editing packages available).
@ VW-BN1 owners - how many mins of video can you get on a double-layer DVD, presumably it's 40 mins?
The Panasonic UK website gives very little info: Panasonic - ideas for life - AVCHD
15-01-2009, 11:40 AM
#12 (permalink)
| | Member
Thanks: Gave 0, Got 0 | Re: Panasonic VW-BN1 disc burner
Does anybody know if the VW-BN1 is the same model as VW-BN1E-S
Or What is the difference
Need a compatible for HDC-SD9
15-01-2009, 8:36 PM
#13 (permalink)
| | Senior Member
Thanks: Gave 31, Got 245 | Re: Panasonic VW-BN1 disc burner Quote:
Originally Posted by gunneredw Does anybody know if the VW-BN1 is the same model as VW-BN1E-S | The "E" more than likely designates that it's the model destined for the European market, and the "S" is probably a colour code - silver?
16-01-2009, 2:08 PM
#14 (permalink)
| | Member
What's the best price anyone has found on this burner?
16-01-2009, 5:16 PM
#15 (permalink)
| | Member
Originally Posted by gunneredw What's the best price anyone has found on this burner? | Empire Direct are doing it at £125
Campkinsonline £117 (though ive never used them)
Ive not factored in any delivery costs though. ED is perhaps the best bet for the sake of £8 difference.
