Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 24th at 3:30pm and include delivery.
screen burn covered by warranty? Mighty Chipster Plasma Televisions 8 13-01-2009 8:57 PM
A new 46" LCD, and a new approach to buying one... Persiflage Which LCD TV Should I Buy? 3 13-01-2009 4:13 PM
Which Sony do i go for grooverider0101 Which LCD TV Should I Buy? 10 13-01-2009 1:37 PM
sony 820 connection check edy172 AV Amplifiers and Receivers 6 12-01-2009 8:42 PM
Sony HT-SF1300 - Quick Q! Kryptonic All-in-one Systems 3 12-01-2009 8:29 PM
Old 12-01-2009, 8:37 PM   #1 (permalink)
Sony HDR-TG3E LCD screen trouble
I have recently got a Sony HDR-TG3E video camera. Just now though when I switched it on the LCD screen is very dim. I have went into settings and set the brightness to the highest setting but this didn't help.
Basically I can see the screen but only just. Any help would be greatly appreciated.
Ps. i have recently been to specsavers to check to see if it was a problem with my eyesight... apparently it wasn't!
dors640 is offline   Reply With Quote
Old 13-01-2009, 9:26 AM   #2 (permalink)
Thanks: Gave 3, Got 23
Re: Sony HDR-TG3E LCD screen trouble
I had a similar problem with my previous camera, the HC3. It turned out that I had somehow activated the "Night Shot" button. Once turned off all was well again. Might be worth checking.
Terry
twoodley is offline   Reply With Quote
Old 13-01-2009, 10:18 AM   #3 (permalink)
Thanks: Gave 1, Got 1
Hi, there is no night shot on the TG3, so its not that.
If you say you have adjusted the screen to maximum brightness, then there is something wrong.
Mine is set to default which is more than bright enough.
This may be a silly question but were you viewing with strong outdoor or sunlight on the screen??
The screen is quite dim or poor when viewed in bright daylight.
If not and the this is indoors.....there is possibly a fault. but without seeing it its hard to say.
Sorry could not have been of more help.
Jon.
Jonathan Fletch is offline   Reply With Quote
hdrtg3e, lcd, screen, sony, trouble
[IMG] code is Off
