Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 24th at 4:30pm and include delivery.
Please help me chose the best satellites spookyelectric Speakers 7 07-01-2009 2:47 PM
Help on choosing a sub !!! peace1 Subwoofers and Tactile Transducers 6 03-01-2009 5:51 PM
906 set up please help townhill22 Onkyo Owners' Forum 3 03-01-2009 2:28 PM
Old 03-01-2009, 10:30 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Need firewire port... no way of adding card, help!
I need a firewire port for capturing DV, but I've just looked into my PC and the ****ing stupid PCIe graphics card is so big that is covers both empty PCI slots.
Great. Any suggestions other than buying a whole new gfx card!
Thanks!
jmp_78 is offline   Reply With Quote
Old 03-01-2009, 10:54 PM   #2 (permalink)
Thanks: Gave 425, Got 2,079
Re: Need firewire port... no way of adding card, help!
Not really
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 04-01-2009, 12:07 AM   #3 (permalink)
sammy4499771's Avatar
Thanks: Gave 31, Got 91
Buy a new computer?
250 gb Apple TV | Macbook Pro | iphone 3G
sammy4499771 is offline   Reply With Quote
Old 05-01-2009, 4:38 PM   #4 (permalink)
Mr Lazy's Avatar
Thanks: Gave 62, Got 118
Your safest option would be to buy a multi-function front panel device (to fit into a spare 5.25" bay) with a Firewire port, such as:
IcyBox IB-861 50 in 1 FIXED Multi Card Reader & Multi Port Panel - Silver - Scan.co.uk
EDIT: was having a blonde moment when I wrote the above - this would just provide the connector - of course you would still need the actual firewire functionality in a card etc.
If you think it will fit you could get a low-profile PCI card, but there is still the risk the graphics card is too big:
Lycom PE-101 2 Port Firewire 1394a PCI-E Controller Low/Hi Profile - Scan.co.uk
I would put a sig here, but I can't be bothered...
Mr Lazy is offline   Reply With Quote
Old 05-01-2009, 8:44 PM   #5 (permalink)
Sorted!
The other side of the gfx card was a very small PCIe slot. Bit a research later - I have a fully functioning Firewire card installed! £25 from Maplin inc cable and software.
Phew
Old 05-01-2009, 8:51 PM   #6 (permalink)
S3Stuff
adding, card, firewire, port
[IMG] code is Off
