Originally Posted by unclepauly Hi,
Looking to buy my first camcorder for some interviewing. I (think) I need the following and am looking for recommendations:
1. External mic connection
2. External headphones connection
3. Cam holder for the external mic so I don't have to hold it (the mic) in my hand
4. Decent still capture facility, want to get a 1080x760 image onto the web
5. Image quality--not so fussy, need something decent enough for web broadcast but better than YouTube, doesn't have to be TV broadcast quality
6. Film data format must be something I can just dump onto a PC and load up into standard editing suites on a MAC or a PC -- no weirdo formats.
7. Recording media -- not fussy, can be digi tape or HD. Not looking to record direct onto DVD.
8. Tough -- will be taking the cam to harsh environements.
All suggestions gratefully received.
Paul |
I'd also suggest the Sony HC9. I use the HC7 for pretty much exactly what you want to do by the sounds of it, and am very pleased with the results. Has ext mic input, headphones out, a funny Sony accessory shoe (which you can get an adaptor for, or I use a standard bracket between the tripod and camera), pretty decent stills (not as good as a dedicated stills cam, but very useable on the web at around 1000 pixels across), good video (is even used for small amounts of broadcast if you know its weaknesses to avoid!), records in HDV to tape, but can export to PC as standard def DV (which is what I do), pretty robust for daily use - but would want to keep it wrapped up from particularly nasty or bumpy environments! It also has "spot focus" so you can touch on the screen where you want it to fix focus, which I find can very easily give fantastic results especially for interviews.
The Canon HV30 is very similar (a few pros, a few cons). They're both getting on for a couple of years old, so I don't know honestly how well or suitably the newer HDD and memory card models compare...
