PLEASE HELP SD9 v Mini DV playback quality in SD
Old 30-12-2008, 12:37 PM   #1
2,018, Level: 10
Points: 2,018, Level: 10 Points: 2,018, Level: 10 Points: 2,018, Level: 10
Question PLEASE HELP SD9 v Mini DV playback quality in SD
I currently have a Mini DV camcorder (sony TRV8 - 8 years old) which gives quite a good picture when burnt to DVD. However it is a bit on the big and heavy side so I am considering purchasing a replacement. Thought to future proof best to get an HD camcorder and the Panasonic HDC-SD9 is in my budget.
The dilemma I have is this - at the moment I have a SD plasma tv and an SD DVD player (and don't have the money to upgrade these, yet) so when I convert the footage to standard definition on a DVD to playback on my current equipment, will the picture quality be worse than / about the same / or, better than what I get with my existing camcorder???
Am feeling pressured because the £50 cashback offer ends tomorrow on the SD9.
Please help - have looked for the answer in the forums but couldn't find any.
Old 30-12-2008, 1:39 PM   #2
8,266, Level: 21
Points: 8,266, Level: 21 Points: 8,266, Level: 21 Points: 8,266, Level: 21
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 16, Got 189
Re: PLEASE HELP SD9 v Mini DV playback quality in SD
It may look more vibrant but the basic quality will be the same,make sure you store all your hd footage for future use.
The main thing is you will have the footage on hd then to make avchd and blu ray discs in the future.
Old 30-12-2008, 1:40 PM   #3
5,766, Level: 18
Points: 5,766, Level: 18 Points: 5,766, Level: 18 Points: 5,766, Level: 18
Thanks: Gave 31, Got 251
In bright light outdoors, at least as good if not better; in average light, about the same; in poor light indoors . . . well, the answer there depends on the size of the chips in your Sony. I believe the TRV8 boasts 1/4" CCDs. The SD9 has 1/6" CCDs. So the SD9 is probably worse in low light than the TRV8. The added resolution can't make up for that.
Still, like the man says, two out of three ain't bad.
Andrew.
Old 30-12-2008, 2:16 PM   #4
2,018, Level: 10
Thanks very much for this - Regarding keeping the High Def footage for future use . Can I just simply burn the HD file now on to a standard DVD?
Thanks for your help
Dan
Old 30-12-2008, 2:41 PM   #5
8,266, Level: 21
Activity: 22.0%
Dan
You must store it on your hard drive or preferably an external drive,putting it on a standard dvd will only be sd footage.
Old 30-12-2008, 3:34 PM   #6
Zaichik's Avatar
5,816, Level: 18
Points: 5,816, Level: 18 Points: 5,816, Level: 18 Points: 5,816, Level: 18
Thanks: Gave 107, Got 18
Not quite true - you can buy a burner for the SD9 which will burn the HD footage on to a DVD. However, the discs can only be played in a player (like the PS3) which supports the HD format.
Old 30-12-2008, 3:49 PM   #7
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Just to clear the air
You can also create an "AVCHD disc" ( such as you are describing) on a PC with suitable software on DVD discs without using any special burner apart from a DVD writer . They also play on suitable BD players ( I have one which can play them) as wellas PS3
As such
Hi def footage can go onto a DVD disc as
  • Data
  • AVCHD disc
or
  • Standard SD DVD after it has been down converted
The first 2 will not play on a Standard DVD player
and the
First one wont play on a Bluray Player or DVD player
Only a PS3 and PC can play all 3
As such DVD discs as " data" storage may prove limiting with only 4.7 Gb/ disc compared to HDD and even as AVCHD disc you only get 20mins worth of footage
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 4:30pm. Prices include delivery.
[IMG] code is Off
