Originally Posted by ChainsawDude Does the memory stick contain seperate .mts files or just a single file? |
Thanks for the response. I'm sorry, how do you mean? I have multiple videos on the MS yes.
Originally Posted by TheBear843 I cant fully answer your question as I am still researching which High-Def camcorder to buy for myself.
I would assume that the PS3 would just display a file for the memory card itself, rather than breaking it down into individual recordings.
I'm wanting a HD camcorder to use via my PS3 also. Can you recommend your Sony CX11E? Is the picture quality impressive when playing back via your PS3?
Hope you get your answer soon
Cheers |
Thanks for reply, yes, but I personally would assume when you select the PRO Duo from the home menu it would show the multiple video files as separate videos, not compile them all into a half-an-hour long single clip.
Sorry, I think I should have made that clearer mate.
And regarding the CX11E, I have only had it a few days but it is bloody good and I can't fault it. Touchscreen and menus are very intuitive to use, the camcorder itself is great to use being well balanced in the hand with easy to use buttons etc. and as for the footage, whether it is the Full HD 1080 or the 10.2 megapixel stills they playback in amazingly realistic quality on the PlayStation.
It does come with a 4Gb MS, which on the standard HD (not Full HD 1080 though) quality records an hour and a half I believe, but I am upgrading to a 16Gb as the current one only records half an hour of 1080P, which is reasonable for what comes in the box I suppose.
Face recognition works really well too with this hilarious smile shutter mode which, when it detects a smile, it automatically takes a photo. On Xmas day I turned it on and was blinding everyone with the flash - the more they laughed the worse it got!
Be aware though that it does not have a viewfinder, just the LCD touchscreen. A bonus for me, but maybe not for all?
In short, look no further for what is, in my opinion, the best HD camcorder around.
