| Re: Sony HDR-SR10 or Panasonic HDC-HS9
Firstly, 24p (or 25p on Euro / UK models) can only be used with the SD9's Digital Cinema Colour mode, designed to work in conjunction with HDTVs that support it, but usually looking highly oversaturated on those that do not. This can be adjusted in editing software, but the fact that the progressive mode cannot be used without DCC is a limitation in my view.
Secondly, 24p / 25p on the SD9 handles movement very poorly. Anything moving through the frame, or any panning movement of the camera, will result in an apparent flicker. AVCHD doesn't handle movement especially well in 50i / 60i; it's worse in progressive.
Having said that, I own an SD9 and love it. Just a matter of working within the limitations.
Andrew.
