Help for Panasonic SD9/HS9
Old 17-12-2008, 1:42 PM   #1
akarit1's Avatar
4,516, Level: 15
Points: 4,516, Level: 15 Points: 4,516, Level: 15 Points: 4,516, Level: 15
Thanks: Gave 52, Got 4
Unhappy Help for Panasonic SD9/HS9
Hi folks,
I wondered if somone could answer a query I have with my HS9 camcorder. It records in 1080P ??
If so then why does my Panasonic PZ81B TV switch to 1080i when I view my footage on the camcorder with a HDMI cable?? My TV is the freesat model and can display multi resolutions so know its not at fault. Is there some sort of setting/adjustment I need to make to view it on my tv as a 1080p picture??
Any help would be much appreciated.
Thanks.
Old 17-12-2008, 1:55 PM   #2
5,766, Level: 18
Points: 5,766, Level: 18 Points: 5,766, Level: 18 Points: 5,766, Level: 18
Thanks: Gave 31, Got 251
Re: Help for Panasonic SD9/HS9
The HS9 records 1080i, not 1080p.
Old 17-12-2008, 5:18 PM   #3
2,893, Level: 12
Points: 2,893, Level: 12 Points: 2,893, Level: 12 Points: 2,893, Level: 12
Thanks: Gave 3, Got 16
Thats not what panasonic say.
Old 17-12-2008, 7:00 PM   #4
5,766, Level: 18
This is true. However, it's "progressive" video that comes in a 50i (or 60i, depending on your flavour - or is that flavor?) wrapper.
Andrew.
Old 18-12-2008, 1:52 PM   #5
akarit1's Avatar
4,516, Level: 15
So theres no way of viewing it directly from the camera in 1080p??
The labels all say full 1080p cancorder - could this be a case of panasonic selling a product which does'nt do what it says on the can???
Old 18-12-2008, 2:09 PM   #6
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Andrew perhaps you might be able to explain how a camcorder records as interlaced but is said to have a progressive output
Also the implication for this during editing. and the value of ouputing as interlaced, not progresive
Leaving any final deinterlacing to the Display
I think I have a fair idea myself but I think that marketing forces have jumped onto the "full HD" bandwagon to convince buyer that nothing less than a "full HD" camcorder is worth its money
To the OP ; FWIW I have 2 HDV camcorders which record in 1080i.. excellent playback on HDTV
Also I tried playing I-Robot bluray disc on a 1080p TV last night . I forced 720p, 1080i and 1080p output from the BD player.
Then watched the SD DVD upscaled to 1080i..
The differences subjectively were far less than I expected but Im sure you may have found
that out yourself using the Denon and PS3 as you do
Old 18-12-2008, 4:57 PM   #7
5,766, Level: 18
Well, I'm not entirely sure how it works with the SD9, I'm just fairly certain that it's not "true" progressive. The SD9 specifications suggest this too, listing "1080/50i" as the signal system - no mention of progressive output there. The only time 25p is actually mentioned in the specs is under "Picture Size" where it simply states that 25p is recorded at 1920x1080.
I suppose one thing I would ask the OP is whether 1920x1080p25 is supported by the PZ81B, according to its own spec sheet - and also whether the clips being tested were definitely recorded using the 25p menu setting.
Andrew.
Old 20-12-2008, 10:14 PM   #8
akarit1's Avatar
4,516, Level: 15
Any views/opinions???
Old 21-12-2008, 8:25 AM   #9
5,766, Level: 18
This from the PZ81B spec sheet:
HDMI Input 1080p: n/a
So it's possible your set doesn't support progressive video across HDMI.
It's a moot point, really, given that it will handle interlaced video, which is better at handling movement than the breed of "progressive" recorded on consumer level camcorders anyway.
EDIT: Looking at page 58 of the PZ81B manual, under "Technical Information" (see attached image), the only HDMI-supported progressive signals listed are 50p, 60p, and 24p. So if you have the US version of the HS9, which records 24p, then it's supported. The UK version of the HS9 has a 25p progressive mode, which according to the table on page 58, isn't supported. The HS9 doesn't shoot 50p or 60p (and in fact nothing does except professional broadcast cameras - and not even all of them).
Andrew.
Help for Panasonic SD9/HS9-tech1.jpg
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
3 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 1:30am. Prices include delivery.
[IMG] code is Off
