Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 1:30am and include delivery.
sony KDL32w4000 vs Sony KDL32v4000 what is the difference ? jimmy55 Which LCD TV Should I Buy? 26 21-10-2008 5:04 PM
Sony Full HD 1080 and Sony HDV1080i - Any difference in video quality apples69 Camcorders and Video Editing 11 30-03-2008 1:19 PM
Whats the difference between the Sony DAV-DZ230 and Sony DAV-DZ231 ? Clarky31 All-in-one Systems 5 25-03-2008 7:58 PM
Sony V3000U vs Sony W3000U...... i'm confused what the difference is? yorkshire_boy LCD Televisions 4 06-11-2007 1:25 PM
Difference between Sony KDL26U2000U and Sony KDL26S2010U? shamblesuk LCD Televisions 2 06-08-2006 3:53 PM
Old 15-12-2008, 12:24 PM   #1 (permalink)
mitch350z's Avatar
Thanks: Gave 3, Got 2
is there any difference between the SONY HDR-S11e/ 12e
hi folks,
gonna get a new camcorder for christmas and i quite like sony stuff and have read good reports of the SONY HD camcorders.
my question is, is there any difference between the HDR-S11e and the HDR- S12e apart from the extra 60GB memory?
and is it noticeable difference if any?
price i dont mind either but should i just get the 12e?
i would only need to record upto around 6hrs at a time before transfering data
TV- Deciding Between Sony 40W3000 and Toshiba 42Z3030??
Car- Nissan 350Z GT now and May 2009 have order number 36 for new Nissan GT-R in Titanium
mitch350z is offline   Reply With Quote
Old 15-12-2008, 2:49 PM   #2 (permalink)
A n d r e w's Avatar
Thanks: Gave 31, Got 245
Re: is there any difference between the SONY HDR-S11e/ 12e
Only one difference that I'm aware of: the size of the internal hard drive. The SR12 has the larger of the two: the specifications on Sony's website will tell you how much by.
Andrew.
These are the sort of windows faces look in at.
A n d r e w is offline   Reply With Quote
Old 16-12-2008, 12:24 AM   #3 (permalink)
mitch350z's Avatar
guys- what is the max recording time for the s11e and s12e in full hd mode?
Old 16-12-2008, 11:37 AM   #4 (permalink)
Thanks: Gave 6, Got 109
The recording times are FH 14HS 40 MIN SR 12 -7 HR 10 MIN SR11
HG 29 HR 40 MIN SR12 -14 HR 40 MIN SR 11
SP 36 HR SR 12-17 HR 50 SR 11
LP 48 HR SR 12-22HR 50 MIN SR 11
Having done a resolution test with my SR12 in all modes the resolution is the same in all of them.
chrishull3 is offline   Reply With Quote
mitch350z (17-12-2008)
Old 17-12-2008, 2:08 PM   #5 (permalink)
mitch350z's Avatar
thanks chris,
are u happy with your sr12e then?recommend it?
Old 18-12-2008, 9:27 AM   #6 (permalink)
thanks chris,
Yes its a great cam,i rarely use my prosumer FX 7 now.
Old 21-12-2008, 12:36 AM   #7 (permalink)
mitch350z's Avatar
think im gonna get the s11e
gonna get an 8gb memory stick for it aswell, think that should be good for around 2hrs full hd recording?
Old 21-12-2008, 8:09 AM   #8 (permalink)
I recommend you ask for an SR11.
The thread title should probably be corrected to facilitate searching . . .
Old 21-12-2008, 10:21 AM   #9 (permalink)
Yes the SR 11 will almost certainly have a big enough hard drive for you especialy if you get the 8 gb memory stick as well,good luck with your cam
Old 21-12-2008, 10:26 AM   #10 (permalink)
And now with £60 cashback I understand
andy_ls26 is offline   Reply With Quote
Old 21-12-2008, 5:26 PM   #11 (permalink)
mitch350z's Avatar
sorry i stand corrected
sr11e reserved from comet to be picked up in store for £610. sounds decent price to me.
do u think there willbe a price drop on the sony range after christmas?or is there another version coming out soon?
dont wanna buy then see that they have dropped in price within 1 week
Old 03-01-2009, 7:46 PM   #12 (permalink)
Thanks: Gave 1, Got 0
I've just bought the SR11E (30th December) and got the same price as you, £610 plus £60 cashback from sony, so effectively £550. Pretty good price I think. Store price was £696 or something but got them to match the internet price :-)
One thing I've noticed though it that the autofocus is a little bit unstable. What i mean by this is that when I was filming my dog indoors the image would keep going very slightly blurred for a split second. Now I'm very much a novice so is this user error, that I was indoors (was fairly light though), that the camera struggled to adapt to my dogs movement (I was only about 2 feet away from my dog) or a problem with the camera?
tobygunnee is offline   Reply With Quote
Old 04-01-2009, 12:55 AM   #13 (permalink)
cdb
Thanks: Gave 2, Got 17
The auto focus seems quite poor on my sr12 in poor lighting. I tried videoing a steam train last year on a misty may day and it just wouldn't focus at all. I had to zoom all the way back in to the closest point and then back out to the train about 100yds away.
You can set it to manual though if the subject won't be moving too much.
cdb is offline   Reply With Quote
12e, difference, hdrs11e or, sony
[IMG] code is Off
