3.5 million visitors each month
Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Sony DCR-SR37E 60GB
Panasonic HDC-SD10
Panasonic SDR-S26
Sony DCR-SR37E 60GB
Panasonic HDC-SD10
Canon Legria FS200
Panasonic HDC-SD200
JVC GZ-MG630 60GB
Sony DCR-SX30E
JVC GZ-MS120
Canon Legria HF200
 More...Prices updated November 8th at 6:30pm and include delivery.
iLink / Firewire Cables RobbieTT Interconnects, Speaker Cables and Switches 3 20-09-2006 11:19 AM
FireWire Cables Upgrade billmalcolm Interconnects, Speaker Cables and Switches 1 14-05-2006 2:31 AM
Firewire cables Anchovy Front Camcorders and Video Editing 8 01-01-2004 5:06 PM
Old 01-12-2008, 10:41 PM   #1 (permalink)
Thanks: Gave 13, Got 0
Firewire Cables - Advice
Can someone please explain the different firewire cables.
My computer has both a 6 pin and what I think is a 4 pin connector (but is described as a "10-1 pin IE1394_2".
What is the difference?
Which should I use to connect, say an HF100?
Gasman2 is offline   Reply With Quote
Old 01-12-2008, 10:48 PM   #2 (permalink)
A n d r e w's Avatar
Thanks: Gave 31, Got 244
Re: Firewire Cables - Advice
HF100 connects with USB, not Firewire. Firewire is for DV and HDV camcorders. 4-pin connectors don't draw power from the computer; 6-pin connectors do. A typical DV/HDV firewire device will have a 4-pin connector at the camera end, requiring a 6-to-4-pin Firewire cable. There is also a 9-pin Firewire port for the FW800 protocol (6-pin ports are for FW400). Couldn't be simpler.
IEEE 1394 interface - Wikipedia, the free encyclopedia
These are the sort of windows faces look in at.
A n d r e w is offline   Reply With Quote
Old 02-12-2008, 11:28 AM   #3 (permalink)
Could you use a 4-pin to 4-pin? Or don't they exist?
So... is my 10-1 a 9-pin? Or is it a 4-pin socket connected to a 9 pin header on the motherboard? Or something else?
If it is a 4-pin on a 9-pin header, could I attach a 9-pin socket to it at some point - if I wanted to?
Old 02-12-2008, 12:00 PM   #4 (permalink)
eSATA
Is eSATA ever used in AV / Camcorder interfaces?
Old 02-12-2008, 5:18 PM   #5 (permalink)
Thanks: Gave 417, Got 2,050
Re: eSATA
No
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 02-12-2008, 5:24 PM   #6 (permalink)
Conspicuous Member
Thanks: Gave 14, Got 447
Yes they do exist and are normally used for connecting a camcorder to a laptop.
Without seeing it it is impossible to say. A 9 pin firewire port should be bigger than a 6 pin port, which is bigger than a 4 pin port.
Have a look at the manual for your motherboard to see if it has onboard firewire800. if it does then you should be able to just connect a different header to get the added speed (for a FW800 device only though).
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
Old 03-12-2008, 11:47 PM   #7 (permalink)
Thanks all
advice, cables, firewire
[IMG] code is Off
