| Re: Advice please - PC or DVD Recorder?
As you will probably already know, capturing to a DVD recorder is fairly simple - just connect them up and hit record.
Using a PC is more time consuming, but will allow you do much more post-processing i.e from basic cutting of video to adding in transitions, video overlays etc. Anyway, USB is definitly not the way to go as you've found out - a Firewire connection is really needed to transfer the DV video to your PC without losing quality.
If you don't have a firewire connection on your PC, you can get a PCI Firewire card to slot into the back of your machine which are relatively cheap. You can use software like Nero to capture the video, but you can get free software (like WinDV) to transfer it over which is free and easy to use. Video capture cards or devices are another option as you say, but I've never used them - and don't think they give the same quality as transferiing the DV video over by firewire.
After you have the DV video on your PC you need to then use video editing software to edit it and convert to a DVD MPEG-2 file. If you encode the video properly I think the quality would be better over PC than the standalone recorder - as you have more control over the encoding process/settings this way. The DVD recorder works essentially by doing an on-the-fly encode to convert the video as it's played to DVD compliant MPEG-2 at a fixed bitrate.
If you want to spend the extra time doing going though this, I could explain further about the software you can use to convert the video. If you're happy enough with the set-up you had before, just og buy another recorder.
