| Re: 1 sec Freeze HV20 Dropouts ???
Hi there, Hope you are well
Dropouts occur more with HDV , so clean the head if you can.
There is no special HDV head but HDV uses a process to compress more Video information on similar tape using the same bitrate as DV so error correction needs to be more fine. The head is identical
Sony Prenuom tapes are fine . IApart from initial foray withthe specisl tapes its all ive ever used and I very rarery get dropouts on the HC1 and FX1
