| Re: Urgent - Filming through the window with my HD camcorder
So long as you aim the camcorder at something far away, yes.
You don't need to "play" with the focus though - as Andrew said, just set the focus setting to infinity (push the joystick all the way to the right). Camcorders have a very deep depth of field anyway, so unless you are shooting something immediately outside the helicopter's window (unlikely I would hope!) everything should be in focus.
By the way, remember that if you do feel the need to zoom in, you need to keep the camcorder very steady, otherwise the picture will shake (a lot). Given the "harsh" enviroment ie. vibration in the helicopter, movement etc. I would avoid zooming much at all. And remember not to pan too fast either.
