Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 4:30pm and include delivery.
D80 help needed - AEB and continuous shooting py6km Digital Photography General Chat 4 29-06-2007 6:31 PM
Continuous lighting help ben66309 Camcorders and Video Editing 0 21-01-2007 5:20 PM
Infocus PJ and continuous fan stryker Projectors 10 20-09-2005 5:18 PM
D70 Continuous shooting mode Madcarpy Digital Photography General Chat 8 16-08-2005 11:23 PM
Cannon S50 or S500 for continuous shooting??? SKT Digital Photography General Chat 1 09-05-2004 2:36 PM
Old 07-10-2008, 12:31 PM   #1 (permalink)
Thanks: Gave 9, Got 0
Continuous Shooting
Hi all,
I was wondering if anyone knows whether it is somehow possible to continuously shoot with a camcorder that takes miniDV tapes without missing anything when you change tapes. Is there some device for instace that can plug into a camcorder in which you can load tapes which records on the next tape in line once the current one has reached the end? It's just that I wanted to film a religious ceremony that will take over 2 hours and I didn't want to miss any of it.
Thanks,
Sachin
sachin is offline   Reply With Quote
Old 07-10-2008, 1:44 PM   #2 (permalink)
Thanks: Gave 37, Got 124
Re: Continuous Shooting
Originally Posted by sachin View Post
Hi all,
Thanks,
Sachin
You could try using the long play mode on the cam if it has one, this gives more recording time.
Also I know that my HV20 can capture live footage directly to my laptop through the firewire output, so it is possible providing you had enough space on your HD to capture more than the 1 hour limit on tape and a cam with this capability and are prepared to use a laptop/pc.
Only other way is to get/borrow another cam to capture the parts you miss while changing the tape
glesgaguyav is offline   Reply With Quote
Old 07-10-2008, 2:30 PM   #3 (permalink)
I thought about using 2 camcorders, about copying direct to pc and about long play mode. For my needs these won't work. Surely someone must have made a mini dv changer - seems like such an obvious invention. Any engineers reading this? You could end up on Dragon's Den!
Old 07-10-2008, 2:51 PM   #4 (permalink)
Mr Lazy's Avatar
Thanks: Gave 62, Got 113
You could get a Firestore Firestore - Portable HDD Recorders - Firestore FS-4 HD 40Gb but they are not cheap.
Failing that, hard drive camcorders are ideal for long shoots, and about the same price as the Firestore.
I would put a sig here, but I can't be bothered...
Mr Lazy is offline   Reply With Quote
Old 07-10-2008, 3:02 PM   #5 (permalink)
Thanks: Gave 425, Got 2,078
Why would 2 camcorders not be ideal for your needs?
Unless they are unattended you wont miss anything if you allow a 1-2 min overlap which can easily be sorted during editing
otherwise capture "live" to HDD on a Laptop . I would rather a laptop than the firestore devices as they work out much cheaper. £299 gets you a half decent new one these days
but
2 Camcorders ( one could be loaned ) works out much cheaper
However to answer you directly , there is no MiniDV tape changer ( domestically or indeed in the industry AFAIK)
You will be surprised how many 2 hr programs you watched have been the result of very skillful editing. In fact you could record the audio ( by whatever means) use a few stills, and then use the next tape in same camcorder to get a seemingly seamless recording
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 07-10-2008, 3:36 PM   #6 (permalink)
Hi all,
thanks for the replies. The reason 2 camcorders aren't a good idea for me is that I only have one :-). The reason why I wasn't considering the hard drive option is because a) I don't know if my camcorder supports it and b) because I wanted a solution that I could use for another thing I wanted to tape as well which is 48 hours long - non-stop! I don't think hard drives would come that big!
Sachin
continuous, shooting
[IMG] code is Off
