Originally Posted by Courtaj The question was what the minimum class requirement was. According to the manual (on page 18 should anyone be bothered to actually consult it), class 4 is the minimum.
Having reiterated this, I now withdraw. |
Actually, the OP did not state his requirements - in fact standard SD cards can be used if you just want to capture stills and/or video which cannot be guaranteed to work reliably.
For guaranteed compatibility at highest framerates/bitrates I would suggest that the OP uses class 6 cards, as a previous poster mentioned the price difference is insignificant.
Obviously, the OP couldn't be bothered to consult the manual (in page 24 of my manual BTW) or he wouldn't be posting here?
