| Re: Mini DV to DVD with no firewire card.
USB is too slow, for full camcorder control by the PC whilst uploading to the PC you need firewire and a lot of hard drive space.
Fitting a Firewire card in a PC is SOOOOOOOOOOO simple.
Take off side panel, knock out one of the blanking plates at the back, plug in card firmly, fix screw, replace panel and switch back on, surprised if it takes more than 5 minutes. Windows does the rest you do not even need drivers if you are running XP or above.
Video editing software can be found in Windows Vista, Nero or download Windows movie maker from Microsoft if not already installed.
