HDMI to DVI - playing HD camera on LCD monitor
Old 05-08-2008, 1:37 PM   #1
5,766, Level: 18
Points: 5,766, Level: 18 Points: 5,766, Level: 18 Points: 5,766, Level: 18
Thanks: Gave 31, Got 251
Is there any reason that using an HDMI to DVI cable to plug a Panasonic SD9 (or equivalent) directly into an LCD computer monitor shouldn't work? Has anyone tried?
I realise that DVI won't carry audio - it's just the video I'd like to look at.
Cheers,
Andrew.
Old 05-08-2008, 6:53 PM   #2
L11 L11 is offline
6,232, Level: 18
Points: 6,232, Level: 18 Points: 6,232, Level: 18 Points: 6,232, Level: 18
Thanks: Gave 5, Got 7
Re: HDMI to DVI - playing HD camera on LCD monitor
doesnt the sd9 use mini hdmi?
Old 05-08-2008, 7:32 PM   #3
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Cheers,
Andrew.
I have s Samsung PC monitor which is also an HDTV but it doesnt have HDMI . It does however have component and DVI and will take any input from them
Indeed I hooked a DVD player to it via DVI using an HDMI to DVI
( The DVD is an upscaling Samsung which has HDMI) and it played without any issues
but a camcorder HDMI directly to a PC monitor .. Im not really so sure
I say this because i couldnt get the DVD player with its HDMI to DVI output to play on another Sony monitor 1280 x1024 max resolution to play :it said the resolution from the DVD player was not supported. I tried varying the resoluting without any luck and gave up
Old 05-08-2008, 7:52 PM   #4
5,766, Level: 18
Yes indeed - noticed that after I posted.
Old 05-08-2008, 7:54 PM   #5
5,766, Level: 18
Cheers, Senu - I've pretty much reached the same conclusion too. Probably not worth buying an HDMI cable just to test a theory that's fairly tenuous to start with.
Still, if anyone has actually had success doing this, do tell.
Andrew.
Old 06-08-2008, 6:43 AM   #6
mmace's Avatar
8,848, Level: 22
Points: 8,848, Level: 22 Points: 8,848, Level: 22 Points: 8,848, Level: 22
Thanks: Gave 27, Got 63
HDMI and DVI are essentially the same except for audio and the way the plugs are laid out, there will be no problems
Old 06-08-2008, 6:49 AM   #7
47,154, Level: 53
Activity: 2.7%
True,
But I could not get my DVD player with HDMI to DVI to play off the PC ,monitor, Was i unlucky? ..( see my post)
The question is whether a Normal PC monitor will readily output a camcorders hi def output, not so much the interface used
I did use another with success but that one is a PC monitor / HDTV
Old 06-08-2008, 7:27 AM   #8
5,766, Level: 18
Right, so basically if it's not an HDTV as well as a monitor then sending HD up the DVI input isn't going to result in a picture.
I knew it was too simple to be true!
Still willing to be disabused of this conclusion, however.
Old 06-08-2008, 6:35 PM   #9
47,154, Level: 53
Activity: 2.7%
Maybe not, all I did was share my experience with you
No harm in trying, since in effect, the only theoretical difference is the presence of a tuner and connections AFAIK
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 3:30pm. Prices include delivery.
[IMG] code is Off
