Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 24th at 8:30am and include delivery.
Blurry motion on BBC HD only? Chalky Sky HD 4 08-10-2007 1:19 PM
MOTION SMEARING (advice please) juicer LCD Televisions 0 25-04-2007 8:00 PM
Advice on Motion Blurr on 37PX60 Plasma bonkersrob Plasma Televisions 8 05-04-2007 4:09 PM
Wharfedale DVDRHD400 Blurry on Hyundai A321..any advice? benhalliday DVD and Blu-ray Recorders, Recording and Media 1 12-03-2007 9:42 AM
Blurry Picture on NEC XG110, Need Advice schmidtsm CRT Projectors 6 28-07-2005 4:44 PM
Old 31-07-2008, 5:11 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Blurry motion advice
Using an old Panny nv-gs27 to record a horse cantering. I firewire to PC and use Adobe Premier 2 for editing. What I am interested in is freeze frame viewing so I can spot when the hoof strikes the ground and then make a note of the time and frame number, then move forward to see when the same foot strikes the ground again, take note of the time and frame number. I then know how long each stride takes. The images I currently get show two legs, so I can't tell in what frame the hoof went down due to the blurring. I have been searching the forum, and it appears that fast shutter speed is needed. Would a faster frame rate above 25fps be of value. What camcorder would be best for this application.
Many thanks.
Faust57 is offline   Reply With Quote
Old 31-07-2008, 5:29 PM   #2 (permalink)
A n d r e w's Avatar
Thanks: Gave 31, Got 245
Re: Blurry motion advice
Frame rate and shutter speed are (relatively) independent of each other. Frame rate is a fixed variable (in the case of standard definition PAL camcorders, it's 25 frames per second; 30 frames per second for NTSC).
Shutter speed, however, is an independent variable. For recording movement, in situations where it is important that there is as little blurring due to movement as possible, shutter speeds of 1/250 or higher are a good idea. Of course, a fast shutter requires plenty of light. But if you're shooting outdoors, you should be able to get as high as 1/250 if you open the iris right up.
I suppose this all depends on what degree of manual control you have on your camera, that is, whether you can adjust shutter speed and iris yourself. You'd have to check your instruction manual.
Andrew.
These are the sort of windows faces look in at.
A n d r e w is offline   Reply With Quote
Mercedes-Ben (11-02-2009)
Old 01-08-2008, 7:38 AM   #3 (permalink)
Thanks, my camera can't adjust anything. I'll look at that as a feature on current camera's, my friend has the Sony HDR-SR8E and the manual doesn't mention manual adjustment.
Old 01-08-2008, 9:54 AM   #4 (permalink)
redsox_mark's Avatar
Thanks: Gave 90, Got 749
The NV-GS27 has manual shutter speed adjustment.
See page 30 of the manual.
Mark
redsox_mark is offline   Reply With Quote
Old 04-08-2008, 1:00 PM   #5 (permalink)
Thanks for the info. Would a progressive recording camera also help?
Old 04-08-2008, 1:40 PM   #6 (permalink)
For frame grabs - yes, progressive helps; no interlacing issues.
Mark
advice, blurry, motion
[IMG] code is Off
