| Re: Hard Drive or SD card camcorder? I was told by one shop assistant that downloading from an SD card has to be done overnight.
That is not correct. Downloading from a SD card is just like copying any files from the card to the PC; the speed will depend on the speed of the card etc, but will be minutes, not hours.
Unless he/she was talking about converting (e.g. from high def AVCHD to standard def), that can take some hours. Also if I bought a 40GB hard drive camcorder is the quality as good as from the mini DV format. I always record in SP mode so how many hours would a 40GB give me in best quality.
There are standard definition and high definition memory card and HDD cams. With standard def, it's about 4.7 GB/hour, so 8 or 9 hours for 40 GB. With high def (generally AVCHD), it depends on the model and the max bitrate it supports, but generally will be a little over half the time of a standard def cam.
What is best depends on your budget, and your preference and way of working. At £300 or less, you tend to get better quality for your money with miniDV, but the choice of models is dropping; the Panasonic GS330 is a good one. At £350 upwards you can consider high def models (the discontinued Panasonic SD5 has been £350 at Amazon for a while now). With high def there are tape (HDV) and flash memory/HDD cams (AVCHD). There is no clear "better" format, you have to look at individual models.
Do you have a budget in mind?
