problem with sony pc105 and via firewire
Old 05-07-2008, 7:43 AM   #1
shmuliks87
Posts: n/a
hi ,
i'm new in here ,
i just got via vt6307 firewire card ,
i have windows xp with sp2
the windows reading the card , in the network plugin i see the 1394 card , and in the system it now as "OHCI Compliant IEEE 1394 Host Controlle"
the problem that from here i can't do noting...
i plug the dvcam with the original cable that i got with the VIA card , i installed the program Ulead Videostudio 8 from the disc that i got with the Via card ,
and when i open the program an try to capture , all i get is
"either no video caputer driver is install in the system , or no device is connected"
one more thing , when i plug the cabel , i shold see something like new hardwere was plugin , like usb???
thanks
Old 05-07-2008, 8:30 AM   #2
Conspicuous Member
21,528, Level: 35
Points: 21,528, Level: 35 Points: 21,528, Level: 35 Points: 21,528, Level: 35
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 4, Got 1,393
Re: problem with sony pc105 and via firewire
Go to your "View Network connections" in My Network and check that the card is not disabled, you right mouse click the Firewire icon to change the status.
Old 05-07-2008, 12:13 PM   #3
shmuliks87
Posts: n/a
so there is a new issue ,
so i did format to the computer , the card where idntinfy ,
when i did the sp2 update , he disapear....
what can i do?
Old 05-07-2008, 12:23 PM   #4
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Reinstall the card
However, before you blame the card
Not recognising the camrcorder may be a camcorder or firewire cable problem
AFAIK, a few Panasonics had this problem for which ther is a fix from microsofts site but if your PC sees the card and says it is working well.. look at the firewire cable, and settings in the camcorder itself
Old 05-07-2008, 7:07 PM   #5
shmuliks87
Posts: n/a
how can i reinstall the card , he dosent have any install....he install from the xp drivers ...
i just dont understad it , how it shold it be , those there is an install for the card those it work in the system like lan card....
Old 05-07-2008, 9:52 PM   #6
47,154, Level: 53
Activity: 2.7%
I meant, remove the card, then resite it ( in its PC slot) so that windows recognises it
If not use system restore to remove the updates to allow the PC back to its previous state ( when the card was recognised)
However I still feel there may be the need to check the camcorder on another PC to see if its cable or camcorder itself are the problem, not the firewire card
Old 06-07-2008, 5:10 PM   #7
shmuliks87
Posts: n/a
good news i think...
i do had new hardwere , 1394 , and it apper agein on the network connetion...with in status connected....
what next??shold i connect also the usb cable to the camera??
Old 06-07-2008, 5:38 PM   #8
47,154, Level: 53
Activity: 2.7%
NO
you need a firewire cable which you should connect to the computer first
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
6 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 13th at 9:30am. Prices include delivery.
[IMG] code is Off
